First off, thank you for your incredible work with this software! Truly wonderful, I've donated and have been spreading the word
I installed pihole via the standard process ( curl -sSL https://install.pi-hole.net | bash).
I am attempting to upgrade, as my Pi-hole version is:
Pi-hole version is v4.3.1 (Latest: v4.3.2)
AdminLTE version is v4.3 (Latest: v4.3.2)
FTL version is v4.3.1 (Latest: v4.3.1)
After running "pihole -up" it reads out:
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] Web Interface: up to date
[i] FTL: up to date
[✓] Everything is up to date!
I have searched through the forum and attempted many of the suggestions:
I am a bit confused I guess. I assumed based on the output when I typed in "pihole -v", that 4.3.2 was the most recent version. When I type in "pihole -u" though, it says it is up to date (despite my system being at 4.3.1).
Nothing? It just returns to the command prompt? That indicates a problem with the OS then. Even if git pull failed, you should see some kind of message.
