The issue I am facing:
Pi-hole doesn't update the search queries and doesn't block adds.
Details about my system:
old dell laptop running ubuntu server, I've got a cat6 cable wired to the router(I think) not the Eero.
ive included a pic showing the physical wiring.
this is the debug token
https://tricorder.pi-hole.net/pCdqtO6F/
can't connect to the internet
Thank y'all so much for making this service free and available! I know it'll work great I just need to set it up correctly
Also I am not sure if the tricorder link I provided is working, because when I click on it I get an empty page so
The link is working, but only Pi-hole developers have access to debug logs.
Ohhhhh makes sense. I guess that shows how much of a noob I am
This would suggest that you haven't configured your router and/or individual clients to use Pi-hole for DNS.
Your debug log would support this, at it shows that your router is still distributing itself as local DNS server:
* Received 300 bytes from enp1s0:192.168.4.1
Offered IP address: 192.168.4.157
DHCP options:
Message type: DHCPOFFER (2)
router: 192.168.4.1
dns-server: 192.168.4.1
Have a read of Pi-hole's Post-Install suggestions to make your network take advantage of Pi-hole .
system
Closed
April 27, 2023, 10:15pm
6
