Reviving this discussion as I now have the same issue:
- Clean reboot is fine
- Brown out (power outtage) means pihole-FTL doesn't load correctly
- Restarting (not starting) pihole-FTL fixes the issue
After brownout:
$ systemctl status pihole-FTL
Active: active (exited) since Fri 2020-10-23 19:14:32 UTC; 24min ago
Process: 1004 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Oct 23 19:14:31 nuc systemd[1]: Starting LSB: pihole-FTL daemon...
Oct 23 19:14:32 nuc pihole-FTL[1004]: Not running
Oct 23 19:14:32 nuc su[1079]: Successful su for pihole by root
Oct 23 19:14:32 nuc su[1079]: + ??? root:pihole
Oct 23 19:14:32 nuc su[1079]: pam_unix(su:session): session opened for user pihole by (uid=0)
Oct 23 19:14:32 nuc pihole-FTL[1004]: dnsmasq: unknown interface eno1
Oct 23 19:14:32 nuc su[1079]: pam_unix(su:session): session closed for user pihole
Oct 23 19:14:32 nuc systemd[1]: Started LSB: pihole-FTL daemon.
If I run $ ps ax | grep pihole | grep -v grep
nothing shows i.e. pihole-FTL is not running.
If I run $ sudo systemctl restart pihole-FTL
Active: active (exited) since Fri 2020-10-23 19:40:05 UTC; 6min ago
Process: 2592 ExecStop=/etc/init.d/pihole-FTL stop (code=exited, status=0/SUCCESS)
Process: 2606 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Oct 23 19:40:05 nuc systemd[1]: Starting LSB: pihole-FTL daemon...
Oct 23 19:40:05 nuc pihole-FTL[2606]: Not running
Oct 23 19:40:05 nuc su[2637]: Successful su for pihole by root
Oct 23 19:40:05 nuc su[2637]: + ??? root:pihole
Oct 23 19:40:05 nuc su[2637]: pam_unix(su:session): session opened for u
Oct 23 19:40:05 nuc pihole-FTL[2606]: FTL started!
Oct 23 19:40:05 nuc su[2637]: pam_unix(su:session): session closed for u
Oct 23 19:40:05 nuc systemd[1]: Started LSB: pihole-FTL daemon.
Which works as expected:
2665 ? S<l 0:01 /usr/bin/pihole-FTL
/var/log/pihole-FTL.log
When a power outtage happens, the end of the logfile (when it doesn't load correctly) is:
[2020-10-23 19:14:32.911 1366M] Imported 12643 queries from the long-term database
[2020-10-23 19:14:32.911 1366M] -> Total DNS queries: 12643
[2020-10-23 19:14:32.911 1366M] -> Cached DNS queries: 2467
[2020-10-23 19:14:32.911 1366M] -> Forwarded DNS queries: 9671
[2020-10-23 19:14:32.911 1366M] -> Blocked DNS queries: 505
[2020-10-23 19:14:32.911 1366M] -> Unknown DNS queries: 0
[2020-10-23 19:14:32.911 1366M] -> Unique domains: 785
[2020-10-23 19:14:32.911 1366M] -> Unique clients: 38
[2020-10-23 19:14:32.911 1366M] -> Known forward destinations: 2
[2020-10-23 19:14:32.911 1366M] Successfully accessed setupVars.conf
After a restart this shows:
[2020-10-23 19:40:05.411 2663M] Imported 12262 queries from the long-term database
[2020-10-23 19:40:05.411 2663M] -> Total DNS queries: 12262
[2020-10-23 19:40:05.411 2663M] -> Cached DNS queries: 2393
[2020-10-23 19:40:05.411 2663M] -> Forwarded DNS queries: 9376
[2020-10-23 19:40:05.411 2663M] -> Blocked DNS queries: 493
[2020-10-23 19:40:05.411 2663M] -> Unknown DNS queries: 0
[2020-10-23 19:40:05.411 2663M] -> Unique domains: 762
[2020-10-23 19:40:05.411 2663M] -> Unique clients: 38
[2020-10-23 19:40:05.411 2663M] -> Known forward destinations: 2
[2020-10-23 19:40:05.411 2663M] Successfully accessed setupVars.conf
[2020-10-23 19:40:05.412 2665M] PID of FTL process: 2665
[2020-10-23 19:40:05.412 2665/T2666] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-23 19:40:05.413 2665/T2668] Listening on Unix socket
[2020-10-23 19:40:05.413 2665/T2667] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-23 19:40:05.419 2665M] Reloading DNS cache
[2020-10-23 19:40:05.419 2665M] Blocking status is enabled
[2020-10-23 19:40:05.446 2665M] INFO: No regex blacklist entries found
[2020-10-23 19:40:05.446 2665M] INFO: No regex whitelist entries found
[2020-10-23 19:40:05.449 2665M] Compiled 0 whitelist and 0 blacklist regex filters for 38 clients in 3.1 msec
ie. there is no PID assigned after a power outtage - which makes sense given there is no process running.
Has anyone else experienced this/know a fix? It's pretty debilitating as I'm not always at home when there is a power outtage (they are quite common) and I have to essentially add backup DNS servers which defeats the point of pihole.
I could implement a script on a crontab every 10 minutes to check for the pihole-FTL process, and issue the restart command, but that is messy and overkill.
A
