Blocked Queries
It's not.
How are you using pi-hole DNS?
Did you set each device to use pi-hole as DNS server or did you set your devices to use the router?
The second option is easier, but you need to add only pi-hole as your DNS server.
Your router is using 2 DNS servers and none of them is your pi-hole:
dns-server: 192.168.1.157
dns-server: 8.8.8.8
But your Pi-hole is on 192.168.1.156
You need to change your router's DNS servers to use only Pi-hole.
