Pi-hole not blocking any URLs
Hi together,
i have set up a Pi-hole with docker-compose. I added my adlists via Dockerfile:
COPY /images/pihole/importfiles/adlists/adlists.sh /
RUN /adlists.sh
RUN rm /adlists.sh -f
The file contains a command to add adlists via CLI:
sqlite3 /etc/pihole/gravity.db "INSERT INTO adlist (address, enabled, comment) VALUES
('https://adaway.org/hosts.txt', 1, 'initial')
The import seems to work fine, as all my imported adlists show up in the GUI.
However, no URL from any of the adlist is being blocked:
2022-04-04_15h28_18
What am I doing wrong?
Greetings, tulpafred
Tools > Generate Debug Log
Edit - Pi-hole blocks domains, not URLs. There is a significant difference between the two.
My debug log can be found on:
https://tricorder.pi-hole.net/d2jaKkyH/
Thanks for helping!
