Hello! I've recently installed Pi-hole on a Raspbery Pi 3B+ and added it to my Ubiquiti Unifi network. After getting it up and running following this guide, the Pi-hole successfully blocked ads as expected for about a day. My Unifi devices (USG-PRO, 8-port 150W Switch, CloudKey)
are all using static IPs except for my AP-PRO, which is DHCP. The Raspbery Pi has a static IP as well.
I'm not quite sure where I'm going wrong. All of my devices show that they are using the Pi-hole's IP as the DNS, and the Pi-hole admin console looks like it's working.
Your debug log shows your Pi-Hole is working properly. The bits of the pihole.log included in the debug log shows it is receiving and replying to DNS queries from some clients ...100.8 and ...100.9.
[✓] affiliate-robot.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] affiliate-robot.com is 0.0.0.0 via Pi-hole (192.168.100.5)
[✓] doubleclick.com is 172.217.9.142 via a remote, public DNS server (8.8.8.8)
Testing steps:
Assign a client DNS directly to the Pi-Hole static IP. Clear the DNS caches on that client and see if Pi-Hole is seeing the traffic from that client (easiest way is to tail the pihole.log).
You have both OpenDNS and your router assigned as upstream DNS servers in Pi-Hole. Remove the router and just use OpenDNS.
Take a careful look through all the router settings (all the tabs). Look for WAN DNS, LAN DNS, DNS rebinding, DDNS, DNS caching, family friendly options, etc. There may be a setting that provides a bypass around the Pi-Hole.
