After setting a single client manually, or the DNS setting on the router, DNS will resolve and ads will be blocked.
Either DNS will not work at all and no site can be reached, or sites load with ads.
This is a fresh install of Raspbian and Pi-hole after a bad SD card. When I test on one machine (Windows) by manually setting the DNS server, it will either load pages with ads or not resolve IP at all. I have updated Pi-hole, rebuilt gravity, and rebooted it several times all to no avail.
You have a setup problem. Your Pi-Hole is setup to listen at IP 20, but there is no IP address assigned on the ethernet interface where you have Pi-Hole listening.
Check your router and ensure the Pi is connected and with a static or reserved IP address. Note that address, then run pihole -r and select "reconfigure" to assign Pi-Hole to listen on that interface and IP address.
[✗] No IPv4 address(es) found on the eth0 interface.
[i] Default IPv4 gateway: 192.168.2.1
* Pinging 192.168.2.1...
[✓] bogeyandbirdie.com is 0.0.0.0 via localhost (127.0.0.1)
[✗] Failed to resolve bogeyandbirdie.com via Pi-hole (192.168.2.20)
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.2.20/24
