I've set some custom hostnames to the ip's using my Pi-hole by defining these in /etc/hosts. This way I can easily recognize the clients. It all worked perfectly until I decided to update Pi-hole this afternoon, to version 3.3. That's where someting went wrong.
In the query log, I can still see the hostname I defined in /etc/hosts:
But if I go to the long term data (pihole query database), it will show the IP address instead of the hostname:
If I search for my defined hostname, you can see that it all went wrong after I updated Pi-hole this afternoon:
The first occurance of the IP is right after that:
The pihole query database (long-term data) should display hostnames.
Instead it displays IP's of clients.
lc6a69xjfv
What can I do about this, if there's anything I can do ?
By the way, yes I'm running Pi-hole on a public server, but I've set my Digitalocean firewall to only accept DNS requests from specified IP's. This way it is not that public anymore
I found it took a few hours before the web interface picked up changes made in /etc/hosts.
Mcat12
February 17, 2018, 2:58am
4
In preparation for the next versions of Pi-hole, the long term stats will store the IP address instead of the hostname. The hostname resolution will happen in the upcoming API.
DL6ER
February 17, 2018, 8:40pm
5
We have added this for the next release of Pi-hole, you can review the proposed changes here:
pi-hole:devel
← pi-hole:new/DB_resolve_hostnames
opened 07:11PM - 17 Feb 18 UTC
- [X] I have re… ad and understood the [contributors guide](https://github.com/pi-hole/AdminLTE/blob/master/CONTRIBUTING.md), as well as this entire template.
- [X] I have made only one major change in my proposed changes.
- [X] I have commented my proposed changes within the code.
- [X] I have tested my proposed changes.
- [X] I am willing to help maintain this change if there are issues with it later.
- [X] I give this submission freely and claim no ownership.
- [X] It is compatible with the [EUPL 1.2 license](https://opensource.org/licenses/EUPL-1.1)
- [X] I have squashed any insignificant commits. ([`git rebase`](http://gitready.com/advanced/2009/02/10/squashing-commits-with-rebase.html))
- [X] I have Signed Off all commits. ([`git commit --signoff`](https://git-scm.com/docs/git-commit#git-commit---signoff))
**What does this PR aim to accomplish?:**
Show host names instead of IP addresses in the long-term data in both `Top Clients` and `Query Log`
**How does this PR accomplish the above?:**
For each IP address we try to obtain the associated host name using the PHP function `gethostbyaddr()`. To avoid calling this function several thousand times (can easily happen with sufficiently extensive requests), we buffer the result for each lookup internally so each IP address is looked up only once per request (regardless of its size). Simple benchmarks indicate that the additional costs by this are on the order of 5%. Hence, they seem acceptable.
If you want to try it out, you can run
sudo pihole checkout web new/DB_resolve_hostnames
Later on, use
sudo pihole checkout web master
to get back to the officially released version or you won't be able to update etc.
Alright, thanks! Looking forward to it
system
Closed
March 12, 2018, 1:30pm
7
