PI Hole is forwarding DNS requests but is not receiving replies
  • Operating System (Family and Version): Pi bookworm
  • Hardware: Raspberry PI 5
  • Core v6.4.2
  • FTL v6.6.1
  • Web interface v6.5
I'm expecting the DNS requests to be forwarded and then returned to the requesting device.
I received a new router from my ISP and my Pi Hole is no longer functioning. I contacted my ISP and they claim neither they nor their new router is blocking port 53 requests.
All endpoints on my network (including my Pi) can send DNS requests and receive responses via my router (192.168.1.1).
For those same devices, if I route DNS requests to the Pi (or 127.0.0.1 locally), I can see in all those requests in the live Pi Hole query log and it is being forwarded just fine. However, no responses are received.
I would like to confirm that it is not a configuration problem on the Pi Hole side.
https://tricorder.pi-hole.net/TrB39H3m/
I see that the debug tests are not able to get a good reply:
[✓] www.sensecapturkiye.com is NOERROR on lo (127.0.0.1)
[✓] www.sensecapturkiye.com is NOERROR on eth0 (192.168.1.10)
[✓] No IPv4 address available on wlan0
[✗] Failed to resolve www.sensecapturkiye.com on wg0 (10.39.18.1)
[✓] www.szlakluxentrix-pl.com is NOERROR on lo (::1)
[✓] No IPv6 address available on eth0
[✓] No IPv6 address available on wlan0
[✓] No IPv6 address available on wg0
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
And the examination of the log files confirm what you found, queries are being forwarded but no reply is being seen.
Can you run a quick dig from the Pi-hole server command line? Something like
dig pi-hole.net @8.8.8.8
and then one to the Pi-hole service:
dig pi-hole.net @192.168.1.10
Both commands result in "communications error to 8.8.8.8#53: timed out".
Interestingly enough, running "nslookup pi-hole.net 8.8.8.8" returns
Server: 8.8.8.8
Address: 8.8.8.8#53
Non-authoritative answer:
Address: 162.244.93.14
That's odd.
How about dig +notcp google.com @8.8.8.8 to check if tcp is being blocked.
And dig +trace google.com @8.8.8.8
communications error to 8.8.8.8#53: timed out, no servers could be reached for both.
Can you paste the full output? Especially the +trace one.
;; communications error to 8.8.8.8#53: timed out
; <<>> DiG 9.18.47-1~deb12u1-Debian <<>> +notcp goog@e.com @8.8.8.8
; <<>> DiG 9.18.47-1~deb12u1-Debian <<>> +trace google.com @8.8.8.8
Hmm, I don't see anything wrong with the Pi-hole configuration and the fact that digs that don't use Pi-hole at all are failing sounds like a network issue.
What kind of modem or router are you using? Any firewall software?
How about the output from sudo iptables -S and sudo iptables -L -v -n
It is a Nokia WiFi Beacon 19. I've even tried to turn the security level of the built in firewall from High -> Low -> Off and Attack Protection to Off as well. Same results!
sudo iptables -S
-P INPUT DROP
-P FORWARD DROP
-P OUTPUT ACCEPT
-N ufw-after-forward
-N ufw-after-input
-N ufw-after-logging-forward
-N ufw-after-logging-input
-N ufw-after-logging-output
-N ufw-after-output
-N ufw-before-forward
-N ufw-before-input
-N ufw-before-logging-forward
-N ufw-before-logging-input
-N ufw-before-logging-output
-N ufw-before-output
-N ufw-logging-allow
-N ufw-logging-deny
-N ufw-not-local
-N ufw-reject-forward
-N ufw-reject-input
-N ufw-reject-output
-N ufw-skip-to-policy-forward
-N ufw-skip-to-policy-input
-N ufw-skip-to-policy-output
-N ufw-track-forward
-N ufw-track-input
-A FORWARD -j ufw-before-forward
-A FORWARD -j ufw-after-forward
-A FORWARD -j ufw-after-logging-forward
-A FORWARD -j ufw-reject-forward
-A FORWARD -j ufw-track-forward
-A OUTPUT -j ufw-before-logging-output
-A OUTPUT -j ufw-before-output
-A OUTPUT -j ufw-after-output
-A OUTPUT -j ufw-after-logging-output
-A OUTPUT -j ufw-reject-output
-A OUTPUT -j ufw-track-output
-A ufw-after-input -p udp -m udp --dport 137 -j ufw-skip-to-policy-input
-A ufw-after-input -p udp -m udp --dport 138 -j ufw-skip-to-policy-input
-A ufw-after-input -p tcp -m tcp --dport 139 -j ufw-skip-to-policy-input
-A ufw-after-input -p tcp -m tcp --dport 445 -j ufw-skip-to-policy-input
-A ufw-after-input -p udp -m udp --dport 67 -j ufw-skip-to-policy-input
-A ufw-after-input -p udp -m udp --dport 68 -j ufw-skip-to-policy-input
-A ufw-after-input -m addrtype --dst-type BROADCAST -j ufw-skip-to-policy-input
-A ufw-after-logging-forward -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW BLOCK] "
-A ufw-after-logging-input -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW BLOCK] "
-A ufw-after-logging-output -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW ALLOW] "
-A ufw-before-forward -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A ufw-before-forward -p icmp -m icmp --icmp-type 3 -j ACCEPT
-A ufw-before-forward -p icmp -m icmp --icmp-type 11 -j ACCEPT
-A ufw-before-forward -p icmp -m icmp --icmp-type 12 -j ACCEPT
-A ufw-before-forward -p icmp -m icmp --icmp-type 8 -j ACCEPT
-N ufw-track-output
-N ufw-user-forward
-N ufw-user-input
-N ufw-user-limit
-N ufw-user-limit-accept
-N ufw-user-logging-forward
-N ufw-user-logging-input
-N ufw-user-logging-output
-N ufw-user-output
-A INPUT -j ufw-before-logging-input
-A INPUT -j ufw-before-input
-A INPUT -j ufw-after-input
-A INPUT -j ufw-after-logging-input
-A INPUT -j ufw-reject-input
-A INPUT -j ufw-track-input
-A FORWARD -j ufw-before-logging-forward
-A ufw-before-forward -j ufw-user-forward
-A ufw-before-input -i lo -j ACCEPT
-A ufw-before-input -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A ufw-before-input -m conntrack --ctstate INVALID -j ufw-logging-deny
-A ufw-before-input -m conntrack --ctstate INVALID -j DROP
-A ufw-before-input -p icmp -m icmp --icmp-type 3 -j ACCEPT
-A ufw-before-input -p icmp -m icmp --icmp-type 11 -j ACCEPT
-A ufw-before-input -p icmp -m icmp --icmp-type 12 -j ACCEPT
-A ufw-before-input -p icmp -m icmp --icmp-type 8 -j ACCEPT
-A ufw-before-input -p udp -m udp --sport 67 --dport 68 -j ACCEPT
-A ufw-before-input -j ufw-not-local
-A ufw-before-input -d 224.0.0.251/32 -p udp -m udp --dport 5353 -j ACCEPT
-A ufw-before-input -d 239.255.255.250/32 -p udp -m udp --dport 1900 -j ACCEPT
-A ufw-before-input -j ufw-user-input
-A ufw-before-logging-forward -m conntrack --ctstate NEW -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW AUDIT] "
-A ufw-before-logging-input -m conntrack --ctstate NEW -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW AUDIT] "
-A ufw-before-logging-output -m conntrack --ctstate NEW -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW AUDIT] "
-A ufw-before-output -o lo -j ACCEPT
-A ufw-before-output -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A ufw-before-output -j ufw-user-output
-A ufw-logging-allow -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW ALLOW] "
-A ufw-logging-deny -m conntrack --ctstate INVALID -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW AUDIT INVALID] "
-A ufw-logging-deny -m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "[UFW BLOCK] "
-A ufw-not-local -m addrtype --dst-type LOCAL -j RETURN
-A ufw-not-local -m addrtype --dst-type MULTICAST -j RETURN
-A ufw-not-local -m addrtype --dst-type BROADCAST -j RETURN
-A ufw-not-local -m limit --limit 3/min --limit-burst 10 -j ufw-logging-deny
-A ufw-not-local -j DROP
-A ufw-skip-to-policy-forward -j DROP
-A ufw-skip-to-policy-input -j DROP
-A ufw-skip-to-policy-output -j ACCEPT
-A ufw-track-output -p tcp -m conntrack --ctstate NEW -j ACCEPT
-A ufw-track-output -p udp -m conntrack --ctstate NEW -j ACCEPT
-A ufw-user-forward -s 10.39.18.0/24 -i wg0 -o eth0 -j ACCEPT
-A ufw-user-input -p udp -m udp --dport 57359 -j ACCEPT
-A ufw-user-input -s 10.39.18.0/24 -i wg0 -p tcp -m tcp --dport 53 -j ACCEPT
-A ufw-user-input -s 10.39.18.0/24 -i wg0 -p udp -m udp --dport 53 -j ACCEPT
-A ufw-user-input -s 192.168.1.0/24 -p tcp -m tcp --dport 22 -j ACCEPT
-A ufw-user-input -s 192.168.1.0/24 -p udp -m udp --dport 22 -j ACCEPT
-A ufw-user-input -p tcp -m tcp --dport 22 -j DROP
-A ufw-user-input -p udp -m udp --dport 22 -j DROP
-A ufw-user-input -p tcp -m tcp --dport 80 -j ACCEPT
-A ufw-user-input -p udp -m udp --dport 80 -j ACCEPT
-A ufw-user-input -s 192.168.1.0/24 -j ACCEPT
-A ufw-user-input -p tcp -m tcp --dport 53 -j ACCEPT
-A ufw-user-input -p udp -m udp --dport 53 -j ACCEPT
-A ufw-user-input -j DROP
-A ufw-user-limit -m limit --limit 3/min -j LOG --log-prefix "[UFW LIMIT BLOCK] "
-A ufw-user-limit -j REJECT --reject-with icmp-port-unreachable
-A ufw-user-limit-accept -j ACCEPT
Chain INPUT (policy DROP 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
 427K   71M ufw-before-logging-input  0    --  *      *       0.0.0.0/0            0.0.0.0/0
 427K   71M ufw-before-input  0    --  *      *       0.0.0.0/0            0.0.0.0/0
  229 21836 ufw-after-input  0    --  *      *       0.0.0.0/0            0.0.0.0/0
  229 21836 ufw-after-logging-input  0    --  *      *       0.0.0.0/0            0.0.0.0/0
  229 21836 ufw-reject-input  0    --  *      *       0.0.0.0/0            0.0.0.0/0
  229 21836 ufw-track-input  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain FORWARD (policy DROP 0 packets, 0 bytes)
    0     0 ufw-before-logging-forward  0    --  *      *       0.0.0.0/0            0.0.0.0/0
    0     0 ufw-before-forward  0    --  *      *       0.0.0.0/0            0.0.0.0/0
    0     0 ufw-after-forward  0    --  *      *       0.0.0.0/0            0.0.0.0/0
    0     0 ufw-after-logging-forward  0    --  *      *       0.0.0.0/0            0.0.0.0/0
    0     0 ufw-reject-forward  0    --  *      *       0.0.0.0/0            0.0.0.0/0
    0     0 ufw-track-forward  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain OUTPUT (policy ACCEPT 4 packets, 336 bytes)
86817  506M ufw-before-logging-output  0    --  *      *       0.0.0.0/0            0.0.0.0/0
86817  506M ufw-before-output  0    --  *      *       0.0.0.0/0            0.0.0.0/0
 4727  770K ufw-after-output  0    --  *      *       0.0.0.0/0            0.0.0.0/0
 4727  770K ufw-after-logging-output  0    --  *      *       0.0.0.0/0            0.0.0.0/0
 4727  770K ufw-reject-output  0    --  *      *       0.0.0.0/0            0.0.0.0/0
 4727  770K ufw-track-output  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
    0     0 ufw-skip-to-policy-input  17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:137
    0     0 ufw-skip-to-policy-input  17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:138
    0     0 ufw-skip-to-policy-input  6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:139
    0     0 ufw-skip-to-policy-input  6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:445
    0     0 ufw-skip-to-policy-input  17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:67
    0     0 ufw-skip-to-policy-input  17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:68
    0     0 ufw-skip-to-policy-input  0    --  *      *       0.0.0.0/0            0.0.0.0/0            ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
    0     0 LOG        0    --  *      *       0.0.0.0/0            0.0.0.0/0            limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
  884  199K LOG        0    --  *      *       0.0.0.0/0            0.0.0.0/0            limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW ALLOW] "
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
    0     0 ACCEPT     0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate RELATED,ESTABLISHED
    0     0 ACCEPT     1    --  *      *       0.0.0.0/0            0.0.0.0/0            icmptype 3
    0     0 ACCEPT     1    --  *      *       0.0.0.0/0            0.0.0.0/0            icmptype 11
    0     0 ACCEPT     1    --  *      *       0.0.0.0/0            0.0.0.0/0            icmptype 12
    0     0 ACCEPT     1    --  *      *       0.0.0.0/0            0.0.0.0/0            icmptype 8
    0     0 ufw-user-forward  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain ufw-before-input (1 references)
  271 76081 ACCEPT     0    --  lo     *       0.0.0.0/0            0.0.0.0/0
18068   12M ACCEPT     0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate RELATED,ESTABLISHED
    0     0 ufw-logging-deny  0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate INVALID
    0     0 DROP       0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate INVALID
  543  151K ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp spt:67 dpt:68
48533 4470K ufw-not-local  0    --  *      *       0.0.0.0/0            0.0.0.0/0
14944 1686K ACCEPT     17   --  *      *       0.0.0.0/0            224.0.0.251          udp dpt:5353
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            239.255.255.250      udp dpt:1900
33589 2784K ufw-user-input  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain ufw-before-logging-forward (1 references)
    0     0 LOG        0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate NEW limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW AUDIT] "
Chain ufw-before-logging-input (1 references)
 2804  225K LOG        0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate NEW limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW AUDIT] "
Chain ufw-before-logging-output (1 references)
  953  204K LOG        0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate NEW limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW AUDIT] "
Chain ufw-before-output (1 references)
  271 76081 ACCEPT     0    --  *      lo      0.0.0.0/0            0.0.0.0/0
23725   79M ACCEPT     0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate RELATED,ESTABLISHED
  914  201K ufw-user-output  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain ufw-logging-allow (0 references)
    0     0 LOG        0    --  *      *       0.0.0.0/0            0.0.0.0/0            limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
    0     0 LOG        0    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate INVALID limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW AUDIT INVALID] "
Chain ufw-not-local (1 references)
  353 18391 RETURN     0    --  *      *       0.0.0.0/0            0.0.0.0/0            ADDRTYPE match dst-type LOCAL
14944 1686K RETURN     0    --  *      *       0.0.0.0/0            0.0.0.0/0            ADDRTYPE match dst-type MULTICAST
33236 2765K RETURN     0    --  *      *       0.0.0.0/0            0.0.0.0/0            ADDRTYPE match dst-type BROADCAST
    0     0 ufw-logging-deny  0    --  *      *       0.0.0.0/0            0.0.0.0/0            limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
    3   180 ACCEPT     6    --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate NEW
  907  201K ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate NEW
Chain ufw-user-forward (1 references)
    0     0 ACCEPT     0    --  wg0    eth0    10.39.18.0/24        0.0.0.0/0
Chain ufw-user-input (1 references)
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:57359
    0     0 ACCEPT     6    --  wg0    *       10.39.18.0/24        0.0.0.0/0            tcp dpt:53
    0     0 ACCEPT     17   --  wg0    *       10.39.18.0/24        0.0.0.0/0            udp dpt:53
    1    52 ACCEPT     6    --  *      *       192.168.1.0/24       0.0.0.0/0            tcp dpt:22
    0     0 ACCEPT     17   --  *      *       192.168.1.0/24       0.0.0.0/0            udp dpt:22
    0     0 DROP       6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:22
    0     0 DROP       17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:22
  347 18044 ACCEPT     6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:80
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:80
33196 2750K ACCEPT     0    --  *      *       192.168.1.0/24       0.0.0.0/0
    0     0 ACCEPT     6    --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:53
    0     0 ACCEPT     17   --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:53
   45 15226 DROP       0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain ufw-user-limit (0 references)
    0     0 LOG        0    --  *      *       0.0.0.0/0            0.0.0.0/0            limit: avg 3/min burst 5 LOG flags 0 level 4 prefix "[UFW LIMIT BLOCK] "
    0     0 REJECT     0    --  *      *       0.0.0.0/0            0.0.0.0/0            reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
Okay, looks like ufw is installed. Try listing the rules from that with sudo ufw status numbered
And I'm wondering if the wireguard setup is somehow blocking or dropping things.
Can you post up the output from sudo ip route get 8.8.8.8 and sudo ip route too to list your routing table.
I've even tried to disable ufw completely and it still has the same problem.
Status: active
     To                         Action      From
[ 1] Anywhere on eth0           ALLOW FWD   10.39.18.0/24 on wg0
[ 2] 57359/udp                  ALLOW IN    Anywhere                   # allow-wireguard
[ 3] 53 on wg0                  ALLOW IN    10.39.18.0/24
[ 4] 22                         ALLOW IN    192.168.1.0/24
[ 5] 22                         DENY IN     Anywhere
[ 6] 80                         ALLOW IN    Anywhere
[ 7] Anywhere                   ALLOW IN    192.168.1.0/24
[ 8] 53/tcp                     ALLOW IN    Anywhere
[ 9] 53/udp                     ALLOW IN    Anywhere
[10] Anywhere                   DENY IN     Anywhere
[11] 22 (v6)                    DENY IN     Anywhere (v6)
[12] 80 (v6)                    ALLOW IN    Anywhere (v6)
[13] 53/tcp (v6)                ALLOW IN    Anywhere (v6)
[14] 53/udp (v6)                ALLOW IN    Anywhere (v6)
[15] Anywhere (v6)              DENY IN     Anywhere (v6)
[16] 57359/udp (v6)             ALLOW IN    Anywhere (v6)              # allow-wireguard
8.8.8.8 via 192.168.1.1 dev eth0 src 192.168.1.10 uid 0
sudo ip route
default via 192.168.1.1 dev eth0 proto dhcp src 192.168.1.10 metric 100
10.39.18.0/24 dev wg0 proto kernel scope link src 10.39.18.1
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.10 metric 100
Those all look fine as well.
One more thing to check.
Can you add a new package, sudo apt install mtr-tiny to add a terminal traceroute display.
Once that is installed, run mtr -n 8.8.8.8 and see if there are dropped packets anywhere and if you can get all the way to 8.8.8.8.
I really appreciate you troubleshooting this with me. Thank you.
raspberrypi (192.168.1.10) -> 8.8.8.8 (8.8.8.8)                                2026-04-30T12:44:13-0700
Keys:  Help   Display mode   Restart statistics   Order of fields   quit
                                                               Packets               Pings
 Host                                                        Loss%   Snt   Last   Avg  Best  Wrst StDev
 1. 192.168.1.1                                               0.0%   221    0.3   0.3   0.2   6.8   0.4
 2. 10.1.30.1                                                38.5%   221    1.2   1.7   1.0  60.2   5.1
 3. 206.81.80.17                                             38.5%   221    5.2   5.1   4.9   5.6   0.1
 4. 108.170.255.179                                          38.5%   221    6.4   6.1   5.9   8.5   0.2
 5. 142.251.224.251                                          38.5%   221    5.0   5.0   4.9   8.8   0.3
 6. 8.8.8.8                                                  38.6%   220    4.9   4.9   4.8   5.5   0.1
So the results are a bit weird. In the beginning, i was getting 99% packet loss after 192.168.1.1. But after a while, the numbers started to improve. Reset stats and did it a couple more times and no more loss??
That's typically an IP address for a router. I'm guessing that is the Nokia's web interface IP? (BTW, that's a damn sexy WiFi router!).
So the issue looks like it's between the LAN and the router. But what is odd is that you have two different classes for numbering. 192.168.1.x/24 on the LAN and then 10.0.0.0/8. But those two nets/subnets will not directly communicate without a router in between doing the directing of traffic.
What is at 192.168.1.1?
192.168.1.1 is the internal address for the router itself.
Does the router have web-based management or is it locked down to phone app management only?
10/8 and 192/24 require some kind of routing fabric to allow traffic to pass between the two and I'm wondering now if there's something on the router that is allowing internal traffic to exit the lan and pass to the wan but is dropping or blocking the wan DNS replies at the network edge.
It has both web GUI and the phone app. I even tried to install a windows based Pi hole equivalent (Technitium) and that doesn't seem to work either. So I'm suspecting you are right!
Something I have discovered after switching to my current ISP :
Those suckers have started using Private IP Address Ranges for their routing and/or peering !!
So keep in mind that it could be the case here too :wink:
If you want to, we can try installing a packet capture package and see if there's anything in the DNS queries that shows where the issue is. I don't know if that will show much if the problem is on the router but at least it's something and we might just get lucky.
I got the router swapped back to the old WiFi 6e router and everything just works now. It was definitely something to do with that Nokia router that was blocking DNS requests. Thank you DanSchaper for helping me troubleshoot.
