On a fresh install of raspbian lite onto a Pi 3B, pi-hole would install and dns would resolve
Pi-hole fails to download and install FTL and others during install. Once timed out, my Pi fails to resolve dns even after adding 8.8.8.8 and 1.1.1.1 to /etc/resolv.conf
Debug token failed to upload due to aforementioned reason
Please run the following command for me this will spit out A LOT of text but you can upload it to pastebin or directly here and it should help us determine what is going on
Unfortunately the install of pi-hole broke all dns function and curl cannot resolve the host install.pi-hole.net even after I change the dns in /etc/resolv.conf
I cannot ping google.com, but get this when I ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=122 time=12.2 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=122 time=11.9 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=122 time=11.8 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=122 time=11.8 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=122 time=12.3 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=122 time=11.8 ms
64 bytes from 8.8.8.8: icmp_seq=7 ttl=122 time=11.8 ms
64 bytes from 8.8.8.8: icmp_seq=8 ttl=122 time=11.9 ms
64 bytes from 8.8.8.8: icmp_seq=9 ttl=122 time=12.3 ms
64 bytes from 8.8.8.8: icmp_seq=10 ttl=122 time=12.0 ms
My /etc/resolv.conf looks like
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 1.1.1.1
You have a firewall rule or some kind of routing that is intercepting traffic on port 53 and redirecting it to 192.168.0.1. It may be rebind protection from your router but that usually is used to in the opposite way, to prevent a local DNS server from responding. This setup is preventing remote DNS servers from responding.
Just need traffic outbound to external port 53. Do not open inbound port 53 as that will allow other users to access your Pi-hole installation and that is a bad thing.
Thanks @DanSchaper, @jfb, @technicalpyro, @anon55913113 for all the help! That resolved my issues entirely! Now to get that dumb ISP device into a working bridge mode
