This week, I would pass to my second project step. Active the pihole for all my network.
I disabled my DHCP on my router and enabled DHCP on my pihole with the same settings.
The pihole DHCP worked fine. I tested it with some DHCP release + renew command on my device.
However after the old router’s leases were gone, there is not net for every device. Consequently, I set up a static IP on my PC to investigate. I just see the gateway and my PC on the network. Pihole was unreachable like the other.
I tried to reconfigure the static-ip without success:
I finally let active my DHCP router just with a range of 2 IP (It was the minimum).The pihole gets its static IP in this way (I set up a MAC rule on the router just to be sure).
By luck, the pihole is faster than my router to give IP addresses to the other devices. It isn’t the best solution. However it seems to do the job.
My quick and dirty solution doesn't work at all.
However the pi-hole with dhcp mode has works well for ~1 week. After it dispare of network. A reboot and it works again. Strange.... I will buy a keyboard to get a log with a local terminal.
If Raspbian Stretch, dhcpcd sets the static IP.
Its not done through the interfaces config file anymore (change it back to manual):
pi@noads:~ $ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
IP etc can be configured in the /etc/dhcpcd.conf file:
I'am on Armbian Stretch.
The dhcpd conf file was one of first things. When i checked, it was ok, in my remember.
To be sure, I will check again.
Thanks!
I has backed to manual config. Sadly the pihole was still unreachable after some days.
Furthermore, Time between 2 downtime seem smaller :-/
I don't understand, the root cause...
I've had similar experiences with Armbian, and I have not yet found the issue. I first thought it was due to the ramlog for logfiles, but I don't think that is the root issue.
I've seen exactly that as well. I really can't figure it out. Happens on a NanoPi Neo, and a NanoPi M1+. Going to try a new OS and see if that changes things.
