We ask that you post the debug token only. This keeps your debug log private - only the Pi-hole team can access the log at the URL you provide and it auto-expires in 48 hours.
Your DHCP server is passing out the IP of itself for DNS, rather than the Pi-hole IP:
Timeout: 10 seconds
* Received 356 bytes from eth0:192.168.2.1
Offered IP address: 192.168.2.197
Server IP address: N/A
Relay-agent IP address: N/A
BOOTP server: Speedport-Pro-Plus/120141.5.0.018.1
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 192.168.2.1
lease-time: 1814400 ( 21d )
netmask: 255.255.255.0
router: 192.168.2.1
dns-server: 192.168.2.1
renewal-time: 907200 ( 10d 12h )
rebinding-time: 1587600 ( 18d 9h )
broadcast: 192.168.2.255
domain-name: "speedport.ip"
--- end of options ---
Your P-hole is configured at a different IP:
[✓] info.my-chatprogram.xyz is 0.0.0.0 on lo (127.0.0.1)
[✓] info.my-chatprogram.xyz is 0.0.0.0 on eth0 (192.168.2.197)
From a client that you believe should be connected to the Pi-Hole for DNS (the PC in this case), from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
nslookup pi.hole
nslookup flurry.com
Are you running any firewall software that would be blocking port 53 traffic? Something is preventing the Pi from connecting to the Google DNS server and to our nameserver:
[i] dig return code: 10
[i] dig response: dig: couldn't get address for 'ns1.pi-hole.net': failure
The Pi nameserver is also set to the router IP. I recommend that you change this to any public DNS like Cloudflare, Quad9, Google, etc. This allows the device to continue to reach the internet in the case of a problem like you are having now.
