Greetings friends Pi-Hole, at the moment I am presenting a problem with the Pi-Hole system that actually seems very good to me, the problem I have is that it is not blocking the new domains added manually, I am testing with a specific domain but it lets it pass and in the Query Log list that domain does not appear, as I can solve this problem, in the main window it indicates that it is performing blocks but as I can check the correct operation of the pi-hole and by the way that it blocks the domains in the entered?
Thank you for the help that you may be able to provide.
Thanks for your reply, the generated token is as follows:
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
