Pi-Hole was working and randomly it shutdown and wont start back up i tried to re-install it but the same error is happing I'm using a windows 10 pro with docker to use pi hole
The Pi-hole system shuts down instant view log down here.
Blockquote [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 20-start.sh: executing...
::: Starting docker specific checks & setup for docker pihole/pihole
[i] Update local cache of available packages...
[✗] Update local cache of available packages
Error: Unable to update package cache. Please try "apt-get update"[cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[fix-attrs.d] done.
[fix-attrs.d] done.
[fix-attrs.d] done.
[fix-attrs.d] done.
[fix-attrs.d] done.
[fix-attrs.d] done.
[fix-attrs.d] done.
Im unable to beacuse the system does not even start.
