The issue I am facing:
I use Pi-hole in his own official container (Docker Hub) and Caddy V2 in his own official container (Docker Hub) on Raspberry Pi 4 (4GB) in network_mode host, which is working, but want to change that to "regular" docker-networks created with "docker network create".
Pi-hole doesn't start with log entry: "DNS resolution is currently unavailable"
Details about my system:
docker-compose.yml of pi-hole:
version: "3"
services:
pihole:
image: pihole/pihole:latest
ports:
- 53:53/tcp
- 53:53/udp
# - 67:67/udp
# - 80:80/tcp
- 1080:1080/tcp
- 443:443/tcp
environment:
- TZ=Europe/Berlin
- DNS1=10.0.0.1
- DNS2=IPV6_ADDRESS
- ServerIP=10.0.1.1
- IPv6=true
- ServerIPv6=IPV6_ADDRESS_ROUTER
- WEBPASSWORD=WEB_PW
- WEB_PORT=1080
- VIRTUAL_HOST=pihole.crackpi.lan
- VIRTUAL_PORT=80
- PROXY_LOCATION=pihole.crackpi.lan
volumes:
- /docker/pihole/etc:/etc/pihole/
- /docker/pihole/dnsmasq:/etc/dnsmasq.d/
# network_mode: host
restart: unless-stopped
networks:
- default
- proxy
networks:
proxy:
external: true
docker-compose.yml of caddy:
version: "3"
services:
caddy:
image: caddy:latest
ports:
- 80:80
# - 443:443
volumes:
- $PWD/CaddyFile:/etc/caddy/Caddyfile
- $PWD/web:/srv
- $PWD/data:/data
- $PWD/config:/config
networks:
- default
- proxy
networks:
proxy:
external: true
Caddyfile:
http://pihole.crackpi.lan {
reverse_proxy localhost:1080
encode zstd gzip
Local DNS Records at Pi-hole Web Interface:
pihole.crackpi.lan 10.0.1.1
Only docker-compose files written above.
Do you have any idea, what my mistake could be?
Thanks in adcance and kind regards,
Agrigor
