run pihole -d while it is down.
do not upload the log yet
once resolution is avail again use the following command to upload the debug log from the failed state cat /var/log/pihole_debug.log | pihole tricorder
The log outputs in your debug log show the problem. You have a huge number of DNS requests, and they eventually overwhelm the capabilities of your Pi (appears to be a Zero?).
[2020-01-11 05:38:16.147 19788] Resizing "/FTL-queries" from 140967936 to 141164544
[2020-01-11 05:38:16.194 19788] Imported 2938661 queries from the long-term database
[2020-01-11 05:38:16.198 19788] -> Total DNS queries: 2938661
[2020-01-11 05:38:16.199 19788] -> Cached DNS queries: 10759
[2020-01-11 05:38:16.199 19788] -> Forwarded DNS queries: 2926812
[2020-01-11 05:38:16.200 19788] -> Exactly blocked DNS queries: 1090
[2020-01-11 05:38:16.200 19788] -> Unknown DNS queries: 0
[2020-01-11 05:38:16.200 19788] -> Unique domains: 498
[2020-01-11 05:38:16.200 19788] -> Unique clients: 25
[2020-01-11 05:38:16.201 19788] -> Known forward destinations: 3
You have almost 3 million DNS requests in 24 hours, which is likely circular traffic due to conditional forwarding. Please post the outputs of the following commands from the Pi terminal:
Thanks for the response. This might be due to what I'm trying to do on my network - please let me know if it's crazy and there's a better way to do it.
I have a Ubiquiti USG (10.0.0.2) that handles IP assignments since it's got a nice UI for static IPs and the like. I figured I'd have it point it's clients to my pi, (10.0.0.3) and all would be merry.
Here's the information you asked for:
root@pihole:/etc/dnsmasq.d# echo ">top-clients" | nc localhost 4711
tail -n25 /var/log/pihole.log0 2254 10.0.20.2
1 1480 10.0.20.3
2 38 127.0.0.1 localhost
3 6 10.0.0.2 unifi
4 2 10.0.110.6
5 2 10.0.0.157
6 2 10.0.0.90 optimus.home.mydomain.com
7 2 10.0.111.6
8 1 10.0.0.190
9 1 10.0.0.165
---EOM---
root@pihole:/etc/dnsmasq.d# echo ">top-domains" | nc localhost 4711
0 2752 panda-rancher-01.home.mydomain.com
1 2742 panda-rancher-01.home.mydomain.com.home.mydomain.com
2 22 panda-rancher-03.home.mydomain.com
3 10 panda-rancher-02.home.mydomain.com
4 8 www.gstatic.com
5 6 rancher.home.mydomain.com
6 6 s3.amazonaws.com
7 6 api.github.com
8 4 ping.ui.com
9 3 3.20.0.10.in-addr.arpa
---EOM---
root@pihole:/etc/dnsmasq.d# tail -n25 /var/log/pihole.log
Jan 14 01:32:44 dnsmasq[15262]: forwarded panda-rancher-01.home.mydomain.com to 10.0.0.1
Jan 14 01:32:44 dnsmasq[15262]: query[A] panda-rancher-01.home.mydomain.com from 10.0.20.2
Jan 14 01:32:44 dnsmasq[15262]: query[AAAA] panda-rancher-01.home.mydomain.com from 10.0.20.2
Jan 14 01:32:44 dnsmasq[15262]: query[AAAA] panda-rancher-01.home.mydomain.com.home.mydomain.com from 10.0.
20.3
Jan 14 01:32:44 dnsmasq[15262]: forwarded panda-rancher-01.home.mydomain.com.home.mydomain.com to 10.0.0.1
Jan 14 01:32:44 dnsmasq[15262]: query[A] panda-rancher-01.home.mydomain.com.home.mydomain.com from 10.0.20.
3
2
20.2
20.2
2
Jan 14 01:32:44 dnsmasq[15262]: query[AAAA] panda-rancher-01.home.mydomain.com from 10.0.20.3
Jan 14 01:32:45 dnsmasq[15262]: forwarded panda-rancher-01.home.mydomain.com to 10.0.0.1
Jan 14 01:32:45 dnsmasq[15262]: query[A] panda-rancher-01.home.mydomain.com from 10.0.20.3
My dnsmsq.d has a 02-custom.conf that might be of interest as well:
root@pihole:/etc/dnsmasq.d# cat 02-custom.conf
# Could use a LB in front of it?
address=/internal.home.mydomain.com/10.0.110.3
address=/external.home.mydomain.com/10.0.111.3
address=/rancher.home.mydomain.com/10.0.10.0
address=/pihole.home.mydomain.com/10.0.0.3
# metallb assigned
address=/unitycache.home.mydomain.com/10.0.110.202
domain=home.mydomain.com,10.0.0.0/16,local
Please generate a new debug log and post the token. The old one is expired and the outputs you show don't match the traffic volume reported in the earlier debug log.
I should mention that in the intervening time I noticed that one of the hosts it was looking for repeatedly was down. I since rebooted that machine and now my dns traffic seems to have stabilized. I'm guessing the error is still there, but it only shows itself when a host is down?
Oh; so you think the issue was just a set of clients being naughty? I was wondering if I somehow had pihole stuck in a loop when this error condition happened.
