I expect Pi-hole to work and stay enabled.
Pi-hole seems to be disabling itself (blocking). 'pihole status' shows blocking is enabled but it still reports it is enabled when I try to run 'pihole enable'.
E.g.
root@raspberrypi:~# pihole status
[✓] DNS service is running
[✗] Pi-hole blocking is Disabled
root@raspberrypi:~# pihole enable
[i] Blocking already enabled, nothing to do
When I log into the web interface, it shows as disabled/Offline and I click the Enable button and then it shows as enabled/Active. But then I click anywhere else or refresh the page and it shows as disabled/Offline again.
It also shows 0 domains in the blocklist but that simply isn't true. I've tried running 'pihole -g' and it shows lots of domains:
root@raspberrypi:~# pihole -g
[i] Pi-hole blocking is disabled
[i] Target: zerodot1.gitlab.io (hosts)
[✓] Status: No changes detected
[i] Target: dbl.oisd.nl ()
[i] Target: jasonhill.co.uk (ytadblock.txt)
[✓] Consolidating blocklists
[✓] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 1252118
[✓] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 1247184
[i] Number of whitelisted domains: 0
[i] Number of blacklisted domains: 69
[i] Number of regex filters: 4
[✓] Parsing domains into hosts format
[✓] Cleaning up stray matter
[✓] Force-reloading DNS service
I've been running Pi-hole successfully for many months now and this just started happening yesterday.
Any ideas?
Let me know if there's any other info I can provide!
[✓] Your debug token is: https://tricorder.pi-hole.net/89s624ar0a
