Arno
June 22, 2020, 8:06pm
1
Read this one: Pi-hole disabling itself/won't enable blocking
Same? That's probably 4.x, I'm on 5.0
There is no setting as mentioned in (my) v5.0.
Pi-hole is blocking.
Pi-hole version is v5.0 (Latest: v5.0)
AdminLTE version is v5.0 (Latest: v5.0)
FTL version is v5.0 (Latest: v5.0)
The web UI shows
(red dot) Offline
(play button) Enable
pihole status
[✓] DNS service is running
[✗] Pi-hole blocking is Disabled
pihole enable
[i] Blocking already enabled, nothing to do
Arno
July 4, 2020, 7:20pm
2
Today I noticed it maybe had something to do with javascript. uMatrix was in the the way I think.
Arno
July 6, 2020, 2:00pm
3
Back to square one again. Even disabling uMatrix doesn't help.
jfb
July 6, 2020, 5:16pm
4
Please post the token generated by
Tools > Generate Debug Log
Arno
July 8, 2020, 4:24pm
5
jfb
July 8, 2020, 4:58pm
7
What is the specific problem now? Pi-hole works but the GUI shows it disabled?
Arno
July 8, 2020, 8:06pm
8
Exactly (see my first post)
DL6ER
July 8, 2020, 8:13pm
9
Please edit /etc/pihole/setupVars.conf
and delete one of these two lines:
BLOCKING_ENABLED=true
BLOCKING_ENABLED=false
They are exclusive and cause issues when both values coexist at the same time. Afterwards, run
pihole restartdns
Arno
July 8, 2020, 9:28pm
13
Thx.
Did read this solution before but then my terminal window was not full screen so it appeared these lines were not in the file (a '@' on each line from line x onward)
This time same thing but you have my token so it has to be in the file and I came with the 'brilliant' idea to maximize the window.
Sorry.
system
Closed
July 29, 2020, 9:30pm
14
