Hello, when I enable the DHCP service on Pi-hole, I notice it blocks a lot more things compared to when I set the Pi-hole's IP as the DNS in the modem. However, after a few minutes, the internet drops. Currently, I've decided to set the range it provides in the Pi-hole interface, excluding the Pi itself from Pi-hole. Does anyone know if this is correct, or should I leave the example: from 192.168.0.2 (Pi-hole's IP) to 192.168.0.100?
Please follow our help template. In particular, you have not provided a debug token.
