Hello,
From Container Station v5 to v6, changes have been made to a wide variety of terminal commands.
How do you currently change the password for a Pi-hole container?
Ciao
Hello,
Ciao
I'm not 100% sure I understood your question, but if you want to know how to change the password for the Web Interface, the command is:
pihole setpassword
Hi, thanks for the reply.
I actually came across the solution yesterday—right here in the forum.
After entering the old command to change the password, the current Container Station displays an overview of all commands.
I had overlooked the new command there, and I wasn’t entirely sure about the syntax either.
But now it’s working.
The next topic would be monitoring and automatically installing newer Pi-hole containers....
Ciao
Glossar
Please, avoid that.
Automatic updates work until something silently/mysteriously brakes.
If you automate the update process and, for some reason, the newer image fails to start, you will end up with a broken network without DNS resolution.
We always suggest to:
Documentation:
...probably a navigation mistake on my part.
But it did increase the range ;D
