Is the PI Hole cloudflared documentation going to be updated to a solution which works or how to setup an alternative DNS encryption program? As (sudo cloudflared service install --legacy) No longer works and I believe the manual installation throws a few errors aswell
I guess you're referring to Cloudflared installation fails with current cloudflared version · Issue #679 · pi-hole/docs · GitHub?
I think none of us is using cloudflared
, so it is unlikely anyone is working on updating the documentation right now.
If you want to write something - go ahead, we are open to pull requests.
