I recently installed Pi-Hole and initially everything was working great. However, now all websites that are attempted to be loaded take quite a bit of time to begin loading. It doesn't matter what website it is....all exhibit the same behavior. Looking at the forums, one of the things I saw that might cause that is having IPV6 turned on but I've ensure it is not being used on Pi-Hole since Xfinity is not supporting it. As soon as I change my DNS servers back to 1.1.1.1 pages load quickly as they had in the past.
Any suggestions as to what I can try to resolve the issue?
I’m at a loss to explain what is going on…I’ve tried two different DNS Servers with the same result:
Please try again or contact the Pi-hole team for assistance.
A local copy of the debug log can be found at: /var/log/pihole_debug.log
Sorry to take so long to get back to you. I finally got the log to upload by turning off my firewall which appears to be causing part of the problem. The token is j3tjzj9ss0. I ran the debug with the firewall on and then uploaded the debug file with the firewall off. I’m using a firewalla blue.....beginning to wonder if that isn’t the reason for the problems with Pi-Hole...if so, any suggestions?
You have provided that debug token as an answer to yourself here, so it likely has escaped the attention of a mod or developer.
As these tokens are valid for a certain time only before they get deleted automatically, it's probably best to supply a new one.
Also, in order to alert a specific forum member of a post relevant to them, or requiring their attention, do reply to one of their post directly, or try @ing them, as I do now for you: @rayandbrenda.
