I'm using pihole as a dhcp server, I assigned some static leases to some clients because those devices should always use the same ip. Those static leases are outside the range of my DHCP server,
but 1 device keeps getting an incorrect IP.
as you can see, the mac address matches.
.233 was the address originally issagned, but I removed that, reset the device.
the leasetime is 24hours.
but after 3 days, the ip is still incorrect.
I think I need to flush some cache, but not sure, what can I do?
yes, it's accurate
if the mac was different, it wouldn't be in the list with active leases.
first I thought the device itself remembered for to long, but then the address wouldn't re appear in the list.
strange, I already tried that, then it didn't work, but now it does,
the only difference now was that I now unplugged the network cable, then removed the entry(using the interface) and then plugged it back in, where earlier I removed the entry, then restarted the device.
