I'd like Pi-Hole to provide DNS service to my VLANs that are segregated and outside of my Secure LAN
When pointing DNS of VLAN to the Pi-Hole IP address the clients on the segregated VLANs can not connect to the internet.
I'm running Pi-Hole in a Docker container on an unRAID server. I have 4 VLANs set up on my Edgerouter X. All VLANs are separated with firewall rules I found on a YouTube guide. No clients can connect through VLANs except unless Secure LAN (VLAN10) initiates. No clients on the guest or IoT networks can initiate contact with the router services (GUEST_TO_LOCAL)
I have asked this question on multiple forums, ubiquiti, Reddit, can't find a solution. Opening port 53 does not work (maybe because of my segregation rules?)
Is the only solution to run 4 separate Pi-Hole instances?
Here is a diagram map of my network: network - Album on Imgur
