I have Pi-hole setup on a raspberry and works great. Now I have a secondary router with DD-WRT for OpenVPN with IPVanish. When I connect the OpenVPN client the DNS servers are with IPVanish and I can no longer block ads with my Pi-hole DNS.
I'm sure there must be some way to configure this but I have tried many settings and get nowhere.
Hi yes I can reach all the routers from Pi-hole, I just cannot get around the OpenVPN routers with IPVanish, is there a way to get around those and use Pi-Hole DNS?
Usually VPN services use their own DNS so that you do not have a DNS leak (revealing your location by using a DNS from that location). In this case, you may be able to use Pi-hole with the VPN's DNS server as the upstream.
