Hello, my pi-hole is not blocking domains added trough the updatelists script by Jacklul, groups are the correct ID, the adlists are showing on the web interface and the gravity db is updating. Seems like only the default list is working.
The script itself doesn't change any default config, it only advise to comment a system job that update de gravity db, since it comes with a cron job that calls pihole -g .
First I thought it was because the the petition was going trough ipv6 but in my logs its answering ipv4 of the same sites.
Raspberry pi3v1.2, RpiOS 64bits
Pi-Hole with Unbound, DNS Over TLS, Updatelists script by Jaklul.
All but the default adlist are assigned to groups 1, 2 or 3. Only the default adlist is assigned to the default group.
But, you have no clients assigned to any group other than the default group. As a result, only the default adlist is in effect - the others are in empty groups.
Thank you, you are right I didn't assigned any client to the lists.
Also, I tried adding ":eth0" to the client lists, but only the traffic on pc connected trough ethernet was being blocked, my phone (wifi) wasn't blocked. Settup is (wifi & eth) -> router -> rpi
Since you have all clients connected to all groups (thus no difference in any of the clients), why not just eliminate your groups and client assignments, and keep all of your adlists and clients in the default group?
