Installed pi-hole on raspberryPi 1 running kali (i know, unsupported), with the hope that I can make it work.
1st try Installed manually using install script, replaced pihole-FTL binary file with 3.0 because the newer one doesn't work on my os version. Downloaded "pihole-FTL-arm-linux-gnueabi.3" and used "install -T -m 0755 pihole-FTL-arm-linux-gnueabi.3 /usr/bin/pihole-FTL" on it. Status Active, not blocking
2nd try installed using https://github.com/oldjamey/pi-hole-kali solution, relaced pihole-FTL again, this time pihole-FTL service did not exist
3rd try repaired point 2 with "pihole -r", replaced again the pihole-FTL binary, service existing and starting, status active, no block.
Using tcpdump i can see dns queries
uname -a
Linux workbox 4.14.71-v6+ #1 Thu Oct 18 08:07:35 UTC 2018 armv6l GNU/Linux
In the last days spent 8 hours+ to make this work. Tried to make another topic earlier but was black-holed.
expected to block Block Ads!
No ad blocking detected
c6t4aq64pr
uz36chfkws
