[i] The install log is located at: /etc/pihole/install.log
[✓] Update complete!
Current Pi-hole version is v5.16.1
Current AdminLTE version is v5.19
Current FTL version is v5.22
pi in ~ at hass
➜ pihole updatechecker
pi in ~ at hass took 7s
➜ pihole -v
Pi-hole version is v5.16.1 (Latest: v5.16.2)
AdminLTE version is v5.19 (Latest: v5.19)
FTL version is v5.22 (Latest: v5.22)
Interesting now it shows this (Latest: v5.16.2) next to the version of Pi-hole.
Do you think it is a small bug since my distro is not supported?
It's not a bug if your disto is not supported. You need to follow the entire set of directions that are displayed.
It appears you are running Debian according to your debug but you have modified it in some way that is preventing us from determining what version of that distribution. What is your /etc/os-release file contents?
