Hi all. Thanks to all the contributor's to this project.
I had a question as i start planning mirgrating to 5.0. I am running multiple instances of PiHole and syncing blacklist/whitelist files one way using rsycn.
based on the files that got updated. So i can curious with 5.0 moving to new method of stroring files in a gravity db. Does any one have any pointers as to how i could acvieve keeping 2 instances in sync if they were both on 5.0?
However, the easiest approach (since you only want a one-way file transfer), is to move the database at /etc/pihole/gravity.db from one Pi to the other, then restart FTL on the destination Pi.
@jfb would it ok to sync the etc/pihole/custom.list as well? Today i add the mapping in my docker-compose file for /etc/hosts and then manually sync the new entries to the other node. If i switch to using this new custom list it could make some of my setup easier.
