Will my pi-hole ever stop working on its own? I was wondering if I need to set up log rotation or if it could do something that would eventually fill up my raspberry pi zero's SD card? Is there maintenance that I would need to do on it?
Pi-Hole has several maintenance features built in. Weekly gravity updates and nightly log rotations. Unless your card is very small, you won’t fill it up with Pi-Hole files. The long term database is the largest file and it holds 365 days data by default. That is going to be less than 1 GB in most cases.
Pi-Hole should continue running as long as the Pi runs.
