Percent blocked counter as well as Queries blocked never updates
Requests are being blocked but counters didnt work
Any idea how to fix that ?
This is the typical display you will see if you are running an adblocker on your browser.
Not sure what you mean by saying this is typical. I expexted counters to be displayed
Seems this was fixed by adding google dns to etc/resolv.conf
Did you also disable the third-party dark mode?
Yes I did
I've even reinstalled everything from scratch...
Only correcton of resolv.conf helped
I'm inclined to believe it was the addons that were not written or supported by the development team. There is nothing in /etc/resolv.conf
that would affect the web interface.
Are you running an ad blocker on that browser? What browser are you running?
Firefox
this happened with and without add blocker (ublock)
How do you access the pihole dashboard? Via pi.hole
, via it's ip address or via a different hostname?
In my case the blue and yellow tile did not load because they was blocked by a filter rule in AdGuard:
