Hi guys,
i installed PiHole on my Orange pi on Armbian. Than set up this DNS on my home router and works perfect. But since the time I installed it on my OrangePi, is not possible to jion anywhere on the lan or wan from this orange pi. There was nothing more installed than clean armbian and pihole. Do you have any idea, what can cause block all the traffic out?
IPtables:
root@orangepipc:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
No, on pihole is not DHCP server, DHCP server is on my home router. Pihole device has static reserved IP address on home router.
I mean, that if I join to pihole device with SSH, I am not able, for example, download anything from the lan or wan, ping to any device on the wan or lan not works. Nothing is blocked in IPTables. Do you have any suggestion?
So the Pi-hole device can not resolve domains or ping other devices by IP address? If so, then check to make sure it has the correct gateway, and make a new debug log (pihole -d).
THX for your reply. Pihole can't resolve domains and can't ping other devices on LAN or WAN.
Gateway is set up correctly. Command " ip -4 route | grep default | cut -d ' ' -f 3" show my actual gateway IP address.
Other client on same LAN can ping to pihole.
On this gateway is set up DHCP server with reserved IP address for pihole. On orange pi pc(pihole dedicated device) is clean "Armbian_5.38_Orangepipc_Ubuntu_xenial_default_3.4.113_desktop" with Kodi and PiHole only. Do you have any other suggestion?
Thank you all fo you, guys. Incident solved. There was some bug on my home gateway, which disconnected this device after 20 seconds. I did upgrade firmware on my home gateway, did factory reset and set up it again and everything works well.
