Currently, PiHole web interface prevents integration inside an iframe (for example, in a panel on home assistant). The lighttpd hardcodes X-Frame-Options
option, that needs to be commented in ordre to enable Phiole in iframe:
X-Frame-Options" => "DENY"
Is is possible to add an option to allow users to disable this settings and keep it accross updates?
See: Option to allow integration of the web ui in a iframe · Issue #67 · pi-hole/web · GitHub
