Hello,
This has happened more than once now, so I thought I would report it.
After an overnight unattended list and program update, I loose all scripts in /opt/pihole except for checkout.sh which is the only one remaining. Pihole 3.1.4, Web 3.1, FTL 2.9.4.
Obviously this means I can't generate a debug token!
Where can I get the scripts or do I need to reinstall pihole to get it all back working again.
As an aside, in the GUI, if I try a manual list update, it does not show any error that the update didn't complete. It just fades out the 'update' bar. Maybe a check or error message could be added?
Thanks
