Connect to PiHole via OpenVPN and LAN
Only VPN clients connect to PiHole
_[This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2019-08-19:20:03:35 debug log has been initialized.
[i] Core: v4.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.1-0-g1a741f6
[i] Web: v4.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3-0-g44aff72
[✓] FTL: v4.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] 1.4.45
[i] 7.3.8
[✓] Ubuntu 18.04.3 LTS
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[i] x86_64
[✓] IPv4 address(es) bound to the eno1 interface:
192.168.0.105/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the eno1 interface:
fe80::c23f:d5ff:fe62:7ff2 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.0.1
* Pinging 192.168.0.1...
[✓] Gateway responded.
*:9090 systemd (IPv6)
*:8999 qbittorren (IPv6)
*:8999 qbittorren (IPv4)
*:8081 qbittorren (IPv6)
[::1]:5432 postgres (IPv6)
127.0.0.1:5432 postgres (IPv4)
*:445 smbd (IPv6)
*:139 smbd (IPv6)
*:445 smbd (IPv4)
*:139 smbd (IPv4)
127.0.0.1:81 nginx (IPv4)
[*:80] is in use by lighttpd
*:443 nginx (IPv4)
*:443 nginx (IPv6)
*:443 nginx (IPv4)
*:443 nginx (IPv6)
*:443 nginx (IPv4)
*:443 nginx (IPv6)
*:443 nginx (IPv4)
*:443 nginx (IPv6)
*:443 nginx (IPv4)
*:443 nginx (IPv6)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
192.168.0.105:8080 sabnzbdplu (IPv4)
[10.8.0.1:53] is in use by pihole-FTL
[192.168.0.105:53] is in use by pihole-FTL
[127.0.0.1:53] is in use by pihole-FTL
[[fe80::d896:fa9d:3121:a1ed]:53] is in use by pihole-FTL
[[fe80::c23f:d5ff:fe62:7ff2]:53] is in use by pihole-FTL
[[::1]:53] is in use by pihole-FTL
[127.0.0.1:4711] is in use by pihole-FTL
[[::1]:4711] is in use by pihole-FTL
*:86 lighttpd (IPv4)
*:86 lighttpd (IPv6)
[✓] banners32.hpg.com.br is 0.0.0.0 via localhost (127.0.0.1)
[✓] banners32.hpg.com.br is 0.0.0.0 via Pi-hole (192.168.0.105)
[✓] doubleclick.com is 172.217.25.142 via a remote, public DNS server (8.8.8.8)
[✓] lighttpd daemon is active
BLOCKING_ENABLED=true
DNSMASQ_LISTENING=local
DNS_FQDN_REQUIRED=false
DNS_BOGUS_PRIV=false
DNSSEC=false
CONDITIONAL_FORWARDING=false
PIHOLE_INTERFACE=eno1
IPV4_ADDRESS=192.168.0.105/24
IPV6_ADDRESS=
PIHOLE_DNS_1=9.9.9.9
PIHOLE_DNS_2=149.112.112.112
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
HTTP/1.1 301 Moved Permanently
Server: nginx
Date: Mon, 19 Aug 2019 08:03:41 GMT
Content-Type: text/html
Content-Length: 162
Connection: keep-alive
Strict-Transport-Security: max-age=15768000; includeSubDomains; preload;
X-Robots-Tag: none
X-Download-Options: noopen
X-Permitted-Cross-Domain-Policies: none
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Referrer-Policy: no-referrer
[✗] Web interface X-Header: X-Header does not match or could not be retrieved.
Server: nginx
Date: Mon, 19 Aug 2019 08:03:42 GMT
Content-Length: 162
X-Robots-Tag: none
-rw-r--r-- 1 root root 2700410 Aug 19 19:36 /etc/pihole/gravity.list
0.0.0.0
0.nextyourcontent.com
0.r.msn.com
0.start.bz
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 381 Aug 19 18:33 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 66 Aug 19 19:36 /etc/pihole/local.list
192.168.0.105 server
192.168.0.105 pi.hole
10.8.0.2 EliteBook.vpn
-rw-r--r-- 1 root root 238 Aug 19 19:35 /etc/pihole/logrotate
/var/log/pihole.log {
su root syslog
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root syslog
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1593 Aug 19 19:35 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
dhcp-name-match=set:wpad-ignore,wpad
dhcp-ignore-names=tag:wpad-ignore
server=9.9.9.9
server=149.112.112.112
local-service
-rw-r--r-- 1 root root 3498 Aug 19 19:36 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 86
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
mimetype.assign = ( ".png" => "image/png",
".jpg" => "image/jpeg",
".jpeg" => "image/jpeg",
".html" => "text/html",
".js" => "application/javascript",
".json" => "application/json",
".txt" => "text/plain",
".svg" => "image/svg+xml" )
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1703 Aug 19 19:35 /etc/cron.d/pihole
34 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
8 13 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 918 Aug 19 19:36 /var/log/lighttpd/error.log
2019-08-19 06:19:38: (log.c.217) server started
2019-08-19 06:19:44: (server.c.1828) server stopped by UID = 0 PID = 1
2019-08-19 06:19:44: (log.c.217) server started
2019-08-19 06:34:26: (server.c.1828) server stopped by UID = 0 PID = 1
2019-08-19 06:35:56: (log.c.217) server started
2019-08-19 06:38:20: (server.c.1828) server stopped by UID = 0 PID = 3229
2019-08-19 06:38:21: (log.c.217) server started
2019-08-19 06:38:21: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2019-08-19 07:08:03: (server.c.1828) server stopped by UID = 0 PID = 1
2019-08-19 07:08:32: (log.c.217) server started
2019-08-19 07:08:32: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2019-08-19 07:35:42: (server.c.1828) server stopped by UID = 0 PID = 1
2019-08-19 07:36:58: (log.c.217) server started
2019-08-19 07:36:58: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
-rw-r--r-- 1 pihole pihole 17954 Aug 19 19:36 /var/log/pihole-FTL.log
[2019-08-19 06:34:28.584 31743] Using log file /var/log/pihole-FTL.log
[2019-08-19 06:34:28.584 31743] ########## FTL started! ##########
[2019-08-19 06:34:28.584 31743] FTL branch: master
[2019-08-19 06:34:28.584 31743] FTL version: v4.3.1
[2019-08-19 06:34:28.584 31743] FTL commit: b60d63f
[2019-08-19 06:34:28.584 31743] FTL date: 2019-05-25 21:37:26 +0200
[2019-08-19 06:34:28.584 31743] FTL user: pihole
[2019-08-19 06:34:28.585 31743] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-08-19 06:34:28.585 31743] SOCKET_LISTENING: only local
[2019-08-19 06:34:28.585 31743] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-08-19 06:34:28.585 31743] MAXDBDAYS: max age for stored queries is 365 days
[2019-08-19 06:34:28.585 31743] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-08-19 06:34:28.585 31743] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-08-19 06:34:28.585 31743] DBINTERVAL: saving to DB file every minute
[2019-08-19 06:34:28.585 31743] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-08-19 06:34:28.585 31743] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-08-19 06:34:28.585 31743] PRIVACYLEVEL: Set to 0
[2019-08-19 06:34:28.585 31743] IGNORE_LOCALHOST: Show queries from localhost
[2019-08-19 06:34:28.585 31743] BLOCKINGMODE: Null IPs for blocked domains
[2019-08-19 06:34:28.585 31743] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-08-19 06:34:28.585 31743] DBIMPORT: Importing history from database
[2019-08-19 06:34:28.585 31743] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-08-19 06:34:28.585 31743] PORTFILE: Using /var/run/pihole-FTL.port
[2019-08-19 06:34:28.585 31743] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-08-19 06:34:28.585 31743] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-08-19 06:34:28.585 31743] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-08-19 06:34:28.585 31743] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-08-19 06:34:28.585 31743] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-08-19 06:34:28.585 31743] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-08-19 06:34:28.585 31743] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-08-19 06:34:28.585 31743] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-08-19 06:34:28.585 31743] PARSE_ARP_CACHE: Active
[2019-08-19 06:34:28.585 31743] Finished config file parsing
[2019-08-19 06:34:28.585 31743] SQLite3 message: cannot open file at line 38452 of [0eca3dd3d3] (14)
[2019-08-19 06:34:28.585 31743] SQLite3 message: os_unix.c:38452: (2) open(/etc/pihole/pihole-FTL.db) - (14)
[2019-08-19 07:35:45.567 21940] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-08-19 07:35:45.567 21940] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-08-19 07:35:45.567 21940] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-08-19 07:35:45.567 21940] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-08-19 07:35:45.567 21940] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-08-19 07:35:45.567 21940] PARSE_ARP_CACHE: Active
[2019-08-19 07:35:45.567 21940] Finished config file parsing
[2019-08-19 07:35:45.568 21940] Database version is 3
[2019-08-19 07:35:45.568 21940] Database successfully initialized
[2019-08-19 07:35:45.568 21940] New forward server: 149.112.112.112 (0/512)
[2019-08-19 07:35:45.568 21940] New forward server: 9.9.9.9 (1/512)
[2019-08-19 07:35:45.568 21940] Imported 374 queries from the long-term database
[2019-08-19 07:35:45.568 21940] -> Total DNS queries: 374
[2019-08-19 07:35:45.568 21940] -> Cached DNS queries: 239
[2019-08-19 07:35:45.568 21940] -> Forwarded DNS queries: 122
[2019-08-19 07:35:45.568 21940] -> Exactly blocked DNS queries: 13
[2019-08-19 07:35:45.568 21940] -> Unknown DNS queries: 0
[2019-08-19 07:35:45.568 21940] -> Unique domains: 43
[2019-08-19 07:35:45.568 21940] -> Unique clients: 3
[2019-08-19 07:35:45.568 21940] -> Known forward destinations: 2
[2019-08-19 07:35:45.568 21940] Successfully accessed setupVars.conf
[2019-08-19 07:35:45.570 21942] PID of FTL process: 21942
[2019-08-19 07:35:45.571 21942] Listening on port 4711 for incoming IPv4 telnet connections
[2019-08-19 07:35:45.571 21942] Listening on port 4711 for incoming IPv6 telnet connections
[2019-08-19 07:35:45.571 21942] Listening on Unix socket
[2019-08-19 07:35:45.571 21942] Received SIGHUP, reloading cache
[2019-08-19 07:35:45.571 21942] Blocking status is enabled
[2019-08-19 07:35:45.571 21942] INFO: No whitelist file found
[2019-08-19 07:35:45.571 21942] Compiled 0 Regex filters and 0 whitelisted domains in 0.0 msec (0 errors)
[2019-08-19 07:35:45.918 21942] /etc/pihole/gravity.list: parsed 115788 domains (took 347.0 ms)
[2019-08-19 07:36:19.737 21942] Received SIGHUP, reloading cache
[2019-08-19 07:36:19.737 21942] Blocking status is enabled
[2019-08-19 07:36:19.737 21942] INFO: No whitelist file found
[2019-08-19 07:36:19.737 21942] Compiled 0 Regex filters and 0 whitelisted domains in 0.0 msec (0 errors)
[2019-08-19 07:36:20.018 21942] /etc/pihole/gravity.list: parsed 115788 domains (took 228.3 ms)
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 331776 Aug 19 19:35 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 Aug 19 19:35 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 98304 Aug 19 19:35 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 20480 Aug 19 19:35 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 48 Aug 19 19:35 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 12288 Aug 19 19:35 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 229376 Aug 19 19:59 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Aug 19 19:35 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 4096 Aug 19 19:35 /dev/shm/FTL-strings
-rw------- 1 postgres postgres 11440 Aug 19 19:08 /dev/shm/PostgreSQL.1966699787
*** [ DIAGNOSING ]: Locale
LANG=en_US.UTF-8
-rw-r--r-- 1 pihole pihole 106649 Aug 19 20:03 /var/log/pihole.log
-----head of pihole.log------
Aug 19 06:34:28 dnsmasq[31780]: started, version pi-hole-2.80 cachesize 10000
Aug 19 06:34:28 dnsmasq[31780]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Aug 19 06:34:28 dnsmasq[31780]: using nameserver 149.112.112.112#53
Aug 19 06:34:28 dnsmasq[31780]: using nameserver 9.9.9.9#53
Aug 19 06:34:28 dnsmasq[31780]: read /etc/hosts - 7 addresses
Aug 19 06:34:28 dnsmasq[31780]: failed to load names from /etc/pihole/local.list: No such file or directory
Aug 19 06:34:28 dnsmasq[31780]: failed to load names from /etc/pihole/black.list: No such file or directory
Aug 19 06:34:28 dnsmasq[31780]: failed to load names from /etc/pihole/gravity.list: No such file or directory
Aug 19 06:34:28 dnsmasq[31780]: query[AAAA] raw.githubusercontent.com from 127.0.0.1
Aug 19 06:34:28 dnsmasq[31780]: forwarded raw.githubusercontent.com to 149.112.112.112
Aug 19 06:34:28 dnsmasq[31780]: forwarded raw.githubusercontent.com to 9.9.9.9
Aug 19 06:34:28 dnsmasq[31780]: reply raw.githubusercontent.com is <CNAME>
Aug 19 06:34:28 dnsmasq[31780]: reply github.map.fastly.net is NODATA-IPv6
Aug 19 06:34:28 dnsmasq[31780]: query[A] raw.githubusercontent.com from 127.0.0.1
Aug 19 06:34:28 dnsmasq[31780]: reply github.map.fastly.net is 151.101.28.133
Aug 19 06:34:29 dnsmasq[31780]: query[A] raw.githubusercontent.com from 127.0.0.1
Aug 19 06:34:29 dnsmasq[31780]: cached raw.githubusercontent.com is <CNAME>
Aug 19 06:34:29 dnsmasq[31780]: cached github.map.fastly.net is 151.101.28.133
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* A local copy of the debug log can be found at: /var/log/pihole_debug.log]_
You can see from the screenshots I have entered the DNS correctly in my TP-Link router.
In dashboard you can also see my OpenVPN client IP being connected, but nothing seems to connect via the router. It's almost as if something in the router is blocking.
I've looked almost everywhere and can't see anything out of place. Maybe a broken router?
UPDATE
I've just discovered I can still ping things like 8.8.8.8 but I can't ping google.com when I have my DNS pointed to PiHole:
