Code for /etc/dnsmasq.d/04-bypass.conf
dhcp-option=tag:SmartDns,6,208.67.222.220
dhcp-host=MA:CA:DD:R:ES:SS,set:SmartDns
The computer I have selected (via mac address) should be not using pihole and should be using the DNS I have set.
I have run sudo service pihole-FTL restart
. What am I missing?
Edit: using Pihole for DHCP
Its not using the DNS is have set.
jfb
November 6, 2019, 11:10pm
4
You need to substitute the MAC address of you client here - notice the spelling of "MAC Address" - this is a placeholder.
Yes I know, I just used that as a place holder. I just didn't want to post the my mac address because I could not remember if it's save or not.
RamSet
November 6, 2019, 11:42pm
9
try with dhcp-option-force
... see if that pushes it properly.
Thanks, The renew of the DHCP worked.
system
Closed
November 28, 2019, 12:39am
11
