I'm having an issue with pi-hole since upgrading to v4.0.0 months ago and still there in v4.1.1.
I whitelisted a common website that pi-hole said it wasn't in the blacklist. However even with the whitelisting it's still blocked and I must all the time disable Pi-hole temporarily when I need to browse the website and re-enable manually after browsing.
Both digikey.ca and digikey.com are not accessible since i've upgraded to v4 months ago.
So far what I found:
Can't access both digikey.com and ca domain until I disable pihole
Issue appeared since v4.0.0 upgrade...now running v4.1.1
Whitelisting does nothing and I cannot find the domain in the blacklist
I don't have the normal pihole block page when I go to digikey.com , just a dns unresolved error when pihole is active.
In your log output, "pciins-046.inscname.net" is blocked by Pi-Hole, which is preventing the browser from following the entire CNAME trail to the requested IP address. Whitelist that domain.
To find out which block list is blocking that domain, run this command from the Pi terminal:
pihole -q -adlist pciins-046.inscname.net
These tools are very helpful in solving problems of this type:
