Is this a known issue with the dev web interface ?
Under client, it no longer translates into the defined hosts in /etc/hosts
Try updating. This may have already been fixed:
I did update. it returned
what's odd though is that the Web Interface Version is
whereas on the one that "works" i have:
The version of the FTLDNS beta you have doesn't quite support updating the usual way. Try these commands:
cd /etc/.pihole && sudo git pull
cd /var/www/html/admin && sudo git pull
pihole -r
After this, the updater should work fine for the FTLDNS beta.
both git commands returned "Already up-to-date."
i ran a repair and I still have the "devel" Interface and not the FTLDNS
Did you flush your browser cache?
Yes I did.
I reverted to master and now I have:
How do I force the FTLDNS web interface like I have the other instance of pi-hole ?
These are the commands in the first FTLDNS beta test thread
echo "FTLDNS" | sudo tee /etc/pihole/ftlbranch
pihole checkout core FTLDNS
pihole checkout web FTLDNS
That's exactly how I installed it.
That doesn't seem to update the web interface.
i'm still with the web interface at 3.3
Run pihole -d
for a debug token.
I purged everything and installed from scratch.
For some reason one of the 3 pi-holes I'm running, installed
The other 2 are now with:
Debug token 1 from pi-hole with Web Interface running the 3.3-56: h33sep6lhg
Debug token 2 from pi-hole with web interface 3.2.1-121 : sjte18cjmi
Investigating...
This one seems fine
