Can pihole do something else than just blocking?
Scenarios:
- Don't block but collect statistics about blacklisted queries
- Redirect
- Notify
Scenarios:
disable blocking
@PA3DSS , yes this is a solution, but I would like something more sophisticated. For example, I would like to block everything in one list but don't block what is in a second list. I would have the logs of both.
For example, I am happy with the default blocking list, and I want everything in that list to be blocked. At the same time, I want to test a second list, in this case, I would like to have a log for each time someone tried to resolve a name in second list, but without blocking it.
The default configuration logs all queries and actions so you can parse the log output to do just about anything you'd like.
There is no way for a DNS server to redirect, DNS doesn't know what protocol the client is using and why it needs to resolve a domain name. If you assume that it is for web traffic then you're still limited by the fact that impersonating an https endpoint is essentially impossible now.
@DanSchaper yes, I can parse the log, but it seems I am redoing what the pihole already did: check if a domain name is inside a list. Redoing what has been already done seems to me a waste of time.
For sure I am naive, but in my mind pihole is something like
log(request)
if request matches list:
block
else:
resolve
in my mind the needed change is
log(request)
do_something
else:
resolve
It's the do_something that is the problem. Pi-hole is a DNS server, it's pretty much limited to converting domains to IP addresses.
What is the do_something that you'd like to see?
do_something, in my case, would be something like = block / log / block and log. Then I can do complicated stuff parsing the logs. Sure, I can parse the full log by myself: but why redoing the filtering pihole already did?
The definition of do_something is linked to a particular group of client and to a particular list
here log is not the usual logging which logs all the requests, but something separate that records only when the domain name is matched to a list.
Let's go back to my first scenario: for some blacklists and some client I want to usual behaviour (do_something=block): block when the domain name hits a blacklist. For other black lists I don't want any change in the DNS behaviour, but I want to log when some device asks to resolve a name into a blacklist (do_something = log).
More specific example: suppose I have some smart devices and I want to know if they are communicating with a specific country's top-level domain, but without blocking them.
Would you be open to financially sponsoring your request?
sorry, I don't think so
The easiest solution is to use an SQL query to the long term database to answer this question.
