Renamed my domain from .home to .home.arpa, do not think I changed anything else. Seems to be working fine as far as getting to remote sites, but the local DNS does not seem to be working correctly. Was having issues with pihole -c not returning info, htop showed a pihole process using 100% of one of the CPU's, and not able to get theo .../admin web page but getting to outside addresses. I restart the raspberrypi, and then I was able to get to http://horndns.home.arpa/admin but selecting "Login", with the correct password, does not go into the admin page. The log stops about 15:21.
Found out drive was out of space, cleared some large foles, but still having issues with pihole, might have deleted a wrong file. Did pihole -g.
Can log into admin page, but still having issues.
instead of lighttpd
Web page .../admin comes up correctly and able to log into admin screen,
