Hello. I'm not able to finish the install on Ubuntu 18.04. Any clues?
root@ICH-SRV-01:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.3 LTS
Release: 18.04
Codename: bionic
root@ICH-SRV-01:~# curl -sSL https://install.pi-hole.net | sudo bash -x
+ set -e
++ cat
+ DNS_SERVERS='Google (ECS);8.8.8.8;8.8.4.4;2001:4860:4860:0:0:0:0:8888;2001:4860:4860:0:0:0:0:8844
OpenDNS (ECS);208.67.222.222;208.67.220.220;2620:119:35::35;2620:119:53::53
Level3;4.2.2.1;4.2.2.2;;
Comodo;8.26.56.26;8.20.247.20;;
DNS.WATCH;84.200.69.80;84.200.70.40;2001:1608:10:25:0:0:1c04:b12f;2001:1608:10:25:0:0:9249:d69b
Quad9 (filtered, DNSSEC);9.9.9.9;149.112.112.112;2620:fe::fe;2620:fe::9
Quad9 (unfiltered, no DNSSEC);9.9.9.10;149.112.112.10;2620:fe::10;2620:fe::fe:10
Quad9 (filtered + ECS);9.9.9.11;149.112.112.11;2620:fe::11;
Cloudflare;1.1.1.1;1.0.0.1;2606:4700:4700::1111;2606:4700:4700::1001'
+ installLogLoc=/etc/pihole/install.log
+ setupVars=/etc/pihole/setupVars.conf
+ lighttpdConfig=/etc/lighttpd/lighttpd.conf
+ coltable=/opt/pihole/COL_TABLE
+ webroot=/var/www/html
+ webInterfaceGitUrl=https://github.com/pi-hole/AdminLTE.git
+ webInterfaceDir=/var/www/html/admin
+ piholeGitUrl=https://github.com/pi-hole/pi-hole.git
+ PI_HOLE_LOCAL_REPO=/etc/.pihole
+ PI_HOLE_FILES=(chronometer list piholeDebug piholeLogFlush setupLCD update version gravity uninstall webpage)
+ PI_HOLE_INSTALL_DIR=/opt/pihole
+ PI_HOLE_CONFIG_DIR=/etc/pihole
+ PI_HOLE_BIN_DIR=/usr/local/bin
+ PI_HOLE_BLOCKPAGE_DIR=/var/www/html/pihole
+ useUpdateVars=false
+ adlistFile=/etc/pihole/adlists.list
+ regexFile=/etc/pihole/regex.list
+ IPV4_ADDRESS=
+ IPV6_ADDRESS=
+ QUERY_LOGGING=true
+ INSTALL_WEB_INTERFACE=true
+ PRIVACY_LEVEL=0
+ '[' -z root ']'
+ '[' -t 0 ']'
+ screen_size='24 80'
+ printf -v rows %d 24
+ printf -v columns %d 80
+ r=12
+ c=40
+ r=20
+ c=70
+ skipSpaceCheck=false
+ reconfigure=false
+ runUnattended=false
+ INSTALL_WEB_SERVER=true
+ [[ -f /opt/pihole/COL_TABLE ]]
+ COL_NC='\e[0m'
+ COL_LIGHT_GREEN='\e[1;32m'
+ COL_LIGHT_RED='\e[1;31m'
+ TICK='[\e[1;32m✓\e[0m]'
+ CROSS='[\e[1;31m✗\e[0m]'
+ INFO='[i]'
+ DONE='\e[1;32m done!\e[0m'
+ OVER='\r\033[K'
+ binary=tbd
+ counter=0
+ [[ '' != true ]]
+ main
+ local 'str=Root user check'
+ printf '\n'
+ [[ 0 -eq 0 ]]
+ printf ' %b %s\n' '[\e[1;32m✓\e[0m]' 'Root user check'
[✓] Root user check
+ show_ascii_berry
+ echo -e '
\e[1;32m.;;,.
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'\''ccll:;ll .oooodc
.;cll.;;looo:.
\e[1;31m.. '\'','\''.
..'\'''\'''\''.\e[0m
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
+ make_temporary_log
++ mktemp /tmp/pihole_temp.XXXXXX
+ TEMPLOG=/tmp/pihole_temp.VSifec
+ exec
+ rm /tmp/pihole_temp.VSifec
+ distro_check
+ is_command apt-get
+ local check_command=apt-get
+ command -v apt-get
+ PKG_MANAGER=apt-get
+ UPDATE_PKG_CACHE='apt-get update'
+ PKG_INSTALL=(${PKG_MANAGER} --yes --no-install-recommends install)
+ PKG_COUNT='apt-get -s -o Debug::NoLocking=true upgrade | grep -c ^Inst || true'
+ APT_SOURCES=/etc/apt/sources.list
+ awk 'BEGIN{a=1;b=0}/bionic main/{a=0}/bionic.*universe/{b=1}END{exit a + b}' /etc/apt/sources.list
+ apt-get install --dry-run iproute2
+ iproute_pkg=iproute2
+ is_command php
+ local check_command=php
+ command -v php
+ [[ '' != true ]]
+ apt-get install --dry-run php
+ phpVer=php
+ apt-get install --dry-run php-sqlite3
+ phpSqlite=sqlite3
+ INSTALLER_DEPS=(apt-utils dialog debconf dhcpcd5 git ${iproute_pkg} whiptail)
+ PIHOLE_DEPS=(cron curl dnsutils iputils-ping lsof netcat psmisc sudo unzip wget idn2 sqlite3 libcap2-bin dns-root-data resolvconf libcap2)
+ PIHOLE_WEB_DEPS=(lighttpd ${phpVer}-common ${phpVer}-cgi ${phpVer}-${phpSqlite})
+ LIGHTTPD_USER=www-data
+ LIGHTTPD_GROUP=www-data
+ LIGHTTPD_CFG=lighttpd.conf.debian
+ [[ -f /etc/pihole/setupVars.conf ]]
+ [[ false == true ]]
+ verifyFreeDiskSpace
+ local 'str=Disk space check'
+ local required_free_kilobytes=51200
+ local existing_free_kilobytes
++ df -Pk
++ grep -m1 '\/$'
++ awk '{print $4}'
+ existing_free_kilobytes=50603056
+ [[ 50603056 =~ ^([0-9])+$ ]]
+ [[ 50603056 -lt 51200 ]]
+ printf ' %b %s\n' '[\e[1;32m✓\e[0m]' 'Disk space check'
[✓] Disk space check
+ update_package_cache
+ local 'str=Update local cache of available packages'
+ printf ' %b %s...' '[i]' 'Update local cache of available packages'
[i] Update local cache of available packages...+ eval 'apt-get update'
+ printf '%b %b %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' 'Update local cache of available packages'
+ notify_package_updates_available
+ local 'str=Checking apt-get for upgraded packages'
+ printf '\n %b %s...' '[i]' 'Checking apt-get for upgraded packages'
[i] Checking apt-get for upgraded packages...++ eval 'apt-get -s -o Debug::NoLocking=true upgrade | grep -c ^Inst || true'
+++ apt-get -s -o Debug::NoLocking=true upgrade
+++ grep -c '^Inst'
+++ true
+ updatesToInstall=0
++ uname -r
+ [[ -d /lib/modules/4.15.0-66-generic ]]
+ [[ 0 -eq 0 ]]
+ printf '%b %b %s... up to date!\n\n' '\r\033[K' '[\e[1;32m✓\e[0m]' 'Checking apt-get for upgraded packages'
+ install_dependent_packages apt-utils dialog debconf dhcpcd5 git iproute2 whiptail
+ counter=1
+ [[ 1 == 1 ]]
+ printf ' %b Installer Dependency checks...\n' '[i]'
+ declare -a installArray
+ is_command debconf-apt-progress
+ local check_command=debconf-apt-progress
+ command -v debconf-apt-progress
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' apt-utils
[i] Checking for apt-utils...+ dpkg-query -W '-f=${Status}' apt-utils
+ grep 'ok installed'
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' apt-utils
[✓] Checking for apt-utils
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' dialog
[i] Checking for dialog...+ dpkg-query -W '-f=${Status}' dialog
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' dialog
[✓] Checking for dialog
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' debconf
[i] Checking for debconf...+ dpkg-query -W '-f=${Status}' debconf
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' debconf
[✓] Checking for debconf
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' dhcpcd5
[i] Checking for dhcpcd5...+ dpkg-query -W '-f=${Status}' dhcpcd5
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' dhcpcd5
[✓] Checking for dhcpcd5
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' git
[i] Checking for git...+ dpkg-query -W '-f=${Status}' git
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' git
[✓] Checking for git
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' iproute2
[i] Checking for iproute2...+ dpkg-query -W '-f=${Status}' iproute2
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' iproute2
[✓] Checking for iproute2
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' whiptail
[i] Checking for whiptail...+ dpkg-query -W '-f=${Status}' whiptail
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' whiptail
[✓] Checking for whiptail
+ [[ 0 -gt 0 ]]
+ printf '\n'
+ return 0
+ checkSelinux
+ is_command getenforce
+ local check_command=getenforce
+ command -v getenforce
+ [[ false == false ]]
+ welcomeDialogs
+ whiptail --msgbox --backtitle Welcome --title 'Pi-hole automated installer' '\n\nThis installer will transform your device into a network-wide ad blocker!' 20 70
+ whiptail --msgbox --backtitle Plea --title 'Free and open source' '\n\nThe Pi-hole is free, but powered by your donations: http://pi-hole.net/donate' 20 70
+ whiptail --msgbox --backtitle 'Initiating network interface' --title 'Static IP Needed' '\n\nThe Pi-hole is a SERVER so it needs a STATIC IP ADDRESS to function properly.
In the next section, you can choose to use your current network settings (DHCP) or to manually edit them.' 20 70
+ mkdir -p /etc/pihole/
+ get_available_interfaces
++ ip --oneline link show up
++ grep -v lo
++ awk '{print $2}'
++ cut -d: -f1
++ cut -d@ -f1
+ availableInterfaces='eno1
tun0'
+ chooseInterface
+ interfacesArray=()
+ local interfacesArray
+ local interfaceCount
+ local chooseInterfaceCmd
+ local chooseInterfaceOptions
+ local firstLoop=1
++ wc -l
+ interfaceCount=2
+ [[ 2 -eq 1 ]]
+ read -r line
+ mode=OFF
+ [[ 1 -eq 1 ]]
+ firstLoop=0
+ mode=ON
+ interfacesArray+=("${line}" "available" "${mode}")
+ read -r line
+ mode=OFF
+ [[ 0 -eq 1 ]]
+ read -r line
+ chooseInterfaceCmd=(whiptail --separate-output --radiolist "Choose An Interface (press space to select)" ${r} ${c} ${interfaceCount})
++ whiptail --separate-output --radiolist 'Choose An Interface (press space to select)' 20 70 2 eno1 available ON tun0 available OFF
+ chooseInterfaceOptions=eno1
+ for desiredInterface in ${chooseInterfaceOptions}
+ PIHOLE_INTERFACE=eno1
+ printf ' %b Using interface: %s\n' '[i]' eno1
[i] Using interface: eno1
+ setDNS
+ local DNSSettingsCorrect
+ DNSChooseOptions=()
+ local DNSServerCount=0
+ OIFS='
+ IFS='
+ for DNSServer in ${DNS_SERVERS}
++ cut '-d;' -f1
+ DNSName='Google (ECS)'
+ DNSChooseOptions[DNSServerCount]='Google (ECS)'
+ (( DNSServerCount=DNSServerCount+1 ))
++ cut '-d;' -f1
+ DNSName='OpenDNS (ECS)'
+ DNSChooseOptions[DNSServerCount]='OpenDNS (ECS)'
++ cut '-d;' -f1
+ DNSName=Level3
+ DNSChooseOptions[DNSServerCount]=Level3
++ cut '-d;' -f1
+ DNSName=Comodo
+ DNSChooseOptions[DNSServerCount]=Comodo
++ cut '-d;' -f1
+ DNSName=DNS.WATCH
+ DNSChooseOptions[DNSServerCount]=DNS.WATCH
++ cut '-d;' -f1
+ DNSName='Quad9 (filtered, DNSSEC)'
+ DNSChooseOptions[DNSServerCount]='Quad9 (filtered, DNSSEC)'
++ cut '-d;' -f1
+ DNSName='Quad9 (unfiltered, no DNSSEC)'
+ DNSChooseOptions[DNSServerCount]='Quad9 (unfiltered, no DNSSEC)'
++ cut '-d;' -f1
+ DNSName='Quad9 (filtered + ECS)'
+ DNSChooseOptions[DNSServerCount]='Quad9 (filtered + ECS)'
++ cut '-d;' -f1
+ DNSName=Cloudflare
+ DNSChooseOptions[DNSServerCount]=Cloudflare
+ DNSChooseOptions[DNSServerCount]=Custom
+ IFS='
++ whiptail --separate-output --menu 'Select Upstream DNS Provider. To use your own, select Custom.' 20 70 7 'Google (ECS)' '' 'OpenDNS (ECS)' '' Level3 '' Comodo '' DNS.WATCH '' 'Quad9 (filtered, DNSSEC)' '' 'Quad9 (unfiltered, no DNSSEC)' '' 'Quad9 (filtered + ECS)' '' Cloudflare '' Custom ''
+ DNSchoices=Cloudflare
+ printf ' %b Using ' '[i]'
[i] Using + [[ Cloudflare == \C\u\s\t\o\m ]]
+ OIFS='
+ IFS='
++ cut '-d;' -f1
+ [[ Cloudflare == \G\o\o\g\l\e\ \(\E\C\S\) ]]
++ cut '-d;' -f1
+ [[ Cloudflare == \O\p\e\n\D\N\S\ \(\E\C\S\) ]]
++ cut '-d;' -f1
+ DNSName=Level3
+ [[ Cloudflare == \L\e\v\e\l\3 ]]
++ cut '-d;' -f1
+ DNSName=Comodo
+ [[ Cloudflare == \C\o\m\o\d\o ]]
++ cut '-d;' -f1
+ DNSName=DNS.WATCH
+ [[ Cloudflare == \D\N\S\.\W\A\T\C\H ]]
++ cut '-d;' -f1
+ [[ Cloudflare == \Q\u\a\d\9\ \(\f\i\l\t\e\r\e\d\,\ \D\N\S\S\E\C\) ]]
++ cut '-d;' -f1
+ [[ Cloudflare == \Q\u\a\d\9\ \(\u\n\f\i\l\t\e\r\e\d\,\ \n\o\ \D\N\S\S\E\C\) ]]
++ cut '-d;' -f1
+ [[ Cloudflare == \Q\u\a\d\9\ \(\f\i\l\t\e\r\e\d\ \+\ \E\C\S\) ]]
++ cut '-d;' -f1
+ [[ Cloudflare == \C\l\o\u\d\f\l\a\r\e ]]
+ printf '%s\n' Cloudflare
Cloudflare
++ cut '-d;' -f2
+ PIHOLE_DNS_1=1.1.1.1
++ cut '-d;' -f3
+ PIHOLE_DNS_2=1.0.0.1
+ break
+ IFS='
+ chooseBlocklists
+ [[ -f /etc/pihole/adlists.list ]]
+ mv /etc/pihole/adlists.list /etc/pihole/adlists.list.old
+ cmd=(whiptail --separate-output --checklist "Pi-hole relies on third party lists in order to block ads.\\n\\nYou can use the suggestions below, and/or add your own after installation\\n\\nTo deselect any list, use the arrow keys and spacebar" "${r}" "${c}" 6)
+ options=(StevenBlack "StevenBlack's Unified Hosts List" on MalwareDom "MalwareDomains" on Cameleon "Cameleon" on DisconTrack "Disconnect.me Tracking" on DisconAd "Disconnect.me Ads" on HostsFile "Hosts-file.net Ads" on)
++ whiptail --separate-output --checklist 'Pi-hole relies on third party lists in order to block ads.\n\nYou can use the suggestions below, and/or add your own after installation\n\nTo deselect any list, use the arrow keys and spacebar' 20 70 6 StevenBlack 'StevenBlack'\''s Unified Hosts List' on MalwareDom MalwareDomains on Cameleon Cameleon on DisconTrack 'Disconnect.me Tracking' on DisconAd 'Disconnect.me Ads' on HostsFile 'Hosts-file.net Ads' on
+ choices='StevenBlack
MalwareDom
Cameleon
DisconTrack
DisconAd
HostsFile'
+ for choice in ${choices}
+ appendToListsFile StevenBlack
+ case $1 in
+ echo https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
+ appendToListsFile MalwareDom
+ case $1 in
+ echo https://mirror1.malwaredomains.com/files/justdomains
+ appendToListsFile Cameleon
+ case $1 in
+ echo http://sysctl.org/cameleon/hosts
+ appendToListsFile DisconTrack
+ case $1 in
+ echo https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
+ appendToListsFile DisconAd
+ case $1 in
+ echo https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
+ appendToListsFile HostsFile
+ case $1 in
+ echo https://hosts-file.net/ad_servers.txt
+ use4andor6
+ local useIPv4
+ local useIPv6
+ cmd=(whiptail --separate-output --checklist "Select Protocols (press space to select)" ${r} ${c} 2)
+ options=(IPv4 "Block ads over IPv4" on IPv6 "Block ads over IPv6" on)
++ whiptail --separate-output --checklist 'Select Protocols (press space to select)' 20 70 2 IPv4 'Block ads over IPv4' on IPv6 'Block ads over IPv6' on
+ choices=IPv4
+ case ${choice} in
+ useIPv4=true
+ [[ -n true ]]
+ find_IPv4_information
+ local route
+ local IPv4bare
++ ip route get 8.8.8.8
+ route='8.8.8.8 via 192.168.1.1 dev eno1 src 192.168.1.5 uid 0
cache '
++ printf 192.168.1.5 uid 0 cache
+ printf -v IPv4bare 192.168.1.5
++ printf 192.168.1.1 dev eno1 src 192.168.1.5 uid 0 cache
+ printf -v IPv4gw 192.168.1.1
+ valid_ip 192.168.1.5
+ local ip=192.168.1.5
+ local stat=1
+ [[ 192.168.1.5 =~ ^[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}$ ]]
+ OIFS='
+ IFS=.
+ ip=(${ip})
+ IFS='
+ [[ 192 -le 255 ]]
+ [[ 168 -le 255 ]]
+ [[ 1 -le 255 ]]
+ [[ 5 -le 255 ]]
+ stat=0
+ return 0
++ ip -oneline -family inet address show
++ grep 192.168.1.5/
++ awk '{print $4}'
++ awk 'END {print}'
+ IPV4_ADDRESS=192.168.1.5/24
+ getStaticIPv4Settings
+ local ipSettingsCorrect
+ whiptail --backtitle 'Calibrating network interface' --title 'Static IP Address' --yesno 'Do you want to use your current network settings as a static address?
IP address: 192.168.1.5/24
Gateway: 192.168.1.1' 20 70
+ whiptail --msgbox --backtitle 'IP information' --title 'FYI: IP Conflict' 'It is possible your router could still try to assign this IP to a device, which would cause a conflict. But in most cases the router is smart enough to not do that.
If you are worried, either manually set the address, or modify the DHCP reservation pool so it does not include the IP you want.
It is also possible to use a DHCP reservation, but if you are going to do that, you might as well set a static address.' 20 70
+ setStaticIPv4
+ local IFCFG_FILE
+ local CONNECTION_NAME
+ [[ -r /etc/sysconfig/network/ifcfg-eno1 ]]
+ [[ -f /etc/dhcpcd.conf ]]
+ setDHCPCD
+ grep -q 192.168.1.5/24 /etc/dhcpcd.conf
+ printf ' %b Static IP already configured\n' '[i]'
[i] Static IP already configured
+ return 0
+ [[ -n '' ]]
+ printf ' %b IPv4 address: %s\n' '[i]' 192.168.1.5/24
[i] IPv4 address: 192.168.1.5/24
+ printf ' %b IPv6 address: %s\n' '[i]' ''
[i] IPv6 address:
+ [[ ! -n true ]]
+ setAdminFlag
+ local WebToggleCommand
+ local WebChooseOptions
+ local WebChoices
+ WebToggleCommand=(whiptail --separate-output --radiolist "Do you wish to install the web admin interface?" ${r} ${c} 6)
+ WebChooseOptions=("On (Recommended)" "" on Off "" off)
++ whiptail --separate-output --radiolist 'Do you wish to install the web admin interface?' 20 70 6 'On (Recommended)' '' on Off '' off
+ WebChoices='On (Recommended)'
+ case ${WebChoices} in
+ printf ' %b Web Interface On\n' '[i]'
[i] Web Interface On
+ [[ true == true ]]
+ WebToggleCommand=(whiptail --separate-output --radiolist "Do you wish to install the web server (lighttpd)?\\n\\nNB: If you disable this, and, do not have an existing webserver installed, the web interface will not function." "${r}" "${c}" 6)
++ whiptail --separate-output --radiolist 'Do you wish to install the web server (lighttpd)?\n\nNB: If you disable this, and, do not have an existing webserver installed, the web interface will not function.' 20 70 6 'On (Recommended)' '' on Off '' off
+ printf ' %b Web Server On\n' '[i]'
[i] Web Server On
+ setLogging
+ local LogToggleCommand
+ local LogChooseOptions
+ local LogChoices
+ LogToggleCommand=(whiptail --separate-output --radiolist "Do you want to log queries?" "${r}" "${c}" 6)
+ LogChooseOptions=("On (Recommended)" "" on Off "" off)
++ whiptail --separate-output --radiolist 'Do you want to log queries?' 20 70 6 'On (Recommended)' '' on Off '' off
+ LogChoices='On (Recommended)'
+ case ${LogChoices} in
+ printf ' %b Logging On.\n' '[i]'
[i] Logging On.
+ setPrivacyLevel
+ local LevelCommand
+ local LevelOptions
+ LevelCommand=(whiptail --separate-output --radiolist "Select a privacy mode for FTL. https://docs.pi-hole.net/ftldns/privacylevels/" "${r}" "${c}" 6)
+ LevelOptions=("0" "Show everything" on "1" "Hide domains" off "2" "Hide domains and clients" off "3" "Anonymous mode" off "4" "Disabled statistics" off)
++ whiptail --separate-output --radiolist 'Select a privacy mode for FTL. https://docs.pi-hole.net/ftldns/privacylevels/' 20 70 6 0 'Show everything' on 1 'Hide domains' off 2 'Hide domains and clients' off 3 'Anonymous mode' off 4 'Disabled statistics' off
+ PRIVACY_LEVEL=0
+ printf ' %b Privacy level %d' '[i]' 0
[i] Privacy level 0+ clone_or_update_repos
+ getGitFiles /etc/.pihole https://github.com/pi-hole/pi-hole.git
+ local directory=/etc/.pihole
+ local remoteRepo=https://github.com/pi-hole/pi-hole.git
+ local 'str=Check for existing repository in /etc/.pihole'
+ printf ' %b %s...' '[i]' 'Check for existing repository in /etc/.pihole'
[i] Check for existing repository in /etc/.pihole...+ is_repo /etc/.pihole
+ local curdir
+ local rc
+ curdir=/root
+ [[ -d /etc/.pihole ]]
+ cd /etc/.pihole
+ git status --short
+ cd /root
+ return 0
+ printf '%b %b %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' 'Check for existing repository in /etc/.pihole'
[✓] Check for existing repository in /etc/.pihole
+ update_repo /etc/.pihole
+ local curdir
+ local 'str=Update repo in /etc/.pihole'
+ curdir=/root
+ cd /etc/.pihole
+ printf ' %b %s...' '[i]' 'Update repo in /etc/.pihole'
[i] Update repo in /etc/.pihole...+ git stash --all --quiet
+ git clean --quiet --force -d
+ git pull --quiet
+ printf '%b %b %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' 'Update repo in /etc/.pihole'
[✓] Update repo in /etc/.pihole
+ cd /root
+ return 0
+ echo ''
+ return 0
+ getGitFiles /var/www/html/admin https://github.com/pi-hole/AdminLTE.git
+ local directory=/var/www/html/admin
+ local remoteRepo=https://github.com/pi-hole/AdminLTE.git
+ local 'str=Check for existing repository in /var/www/html/admin'
+ printf ' %b %s...' '[i]' 'Check for existing repository in /var/www/html/admin'
[i] Check for existing repository in /var/www/html/admin...+ is_repo /var/www/html/admin
+ local curdir
+ local rc
+ curdir=/root
+ [[ -d /var/www/html/admin ]]
+ cd /var/www/html/admin
+ cd /root
+ return 0
+ printf '%b %b %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' 'Check for existing repository in /var/www/html/admin'
[✓] Check for existing repository in /var/www/html/admin
+ update_repo /var/www/html/admin
+ local curdir
+ local 'str=Update repo in /var/www/html/admin'
+ curdir=/root
+ printf ' %b %s...' '[i]' 'Update repo in /var/www/html/admin'
[i] Update repo in /var/www/html/admin...+ git stash --all --quiet
+ git pull --quiet
+ printf '%b %b %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' 'Update repo in /var/www/html/admin'
[✓] Update repo in /var/www/html/admin
+ cd /root
+ return 0
+ echo ''
+ return 0
+ dep_install_list=("${PIHOLE_DEPS[@]}")
+ local dep_install_list
+ dep_install_list+=("${PIHOLE_WEB_DEPS[@]}")
+ install_dependent_packages cron curl dnsutils iputils-ping lsof netcat psmisc sudo unzip wget idn2 sqlite3 libcap2-bin dns-root-data resolvconf libcap2 lighttpd php-common php-cgi php-sqlite3
+ counter=2
+ [[ 2 == 1 ]]
+ printf ' %b Main Dependency checks...\n' '[i]'
[i] Main Dependency checks...
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' cron
[i] Checking for cron...+ dpkg-query -W '-f=${Status}' cron
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' cron
[✓] Checking for cron
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' curl
[i] Checking for curl...+ dpkg-query -W '-f=${Status}' curl
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' curl
[✓] Checking for curl
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' dnsutils
[i] Checking for dnsutils...+ dpkg-query -W '-f=${Status}' dnsutils
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' dnsutils
[✓] Checking for dnsutils
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' iputils-ping
[i] Checking for iputils-ping...+ dpkg-query -W '-f=${Status}' iputils-ping
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' iputils-ping
[✓] Checking for iputils-ping
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' lsof
[i] Checking for lsof...+ dpkg-query -W '-f=${Status}' lsof
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' lsof
[✓] Checking for lsof
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' netcat
[i] Checking for netcat...+ dpkg-query -W '-f=${Status}' netcat
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' netcat
[✓] Checking for netcat
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' psmisc
[i] Checking for psmisc...+ dpkg-query -W '-f=${Status}' psmisc
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' psmisc
[✓] Checking for psmisc
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' sudo
[i] Checking for sudo...+ dpkg-query -W '-f=${Status}' sudo
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' sudo
[✓] Checking for sudo
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' unzip
[i] Checking for unzip...+ dpkg-query -W '-f=${Status}' unzip
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' unzip
[✓] Checking for unzip
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' wget
[i] Checking for wget...+ dpkg-query -W '-f=${Status}' wget
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' wget
[✓] Checking for wget
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' idn2
[i] Checking for idn2...+ dpkg-query -W '-f=${Status}' idn2
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' idn2
[✓] Checking for idn2
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' sqlite3
[i] Checking for sqlite3...+ dpkg-query -W '-f=${Status}' sqlite3
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' sqlite3
[✓] Checking for sqlite3
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' libcap2-bin
[i] Checking for libcap2-bin...+ dpkg-query -W '-f=${Status}' libcap2-bin
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' libcap2-bin
[✓] Checking for libcap2-bin
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' dns-root-data
[i] Checking for dns-root-data...+ dpkg-query -W '-f=${Status}' dns-root-data
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' dns-root-data
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' resolvconf
[i] Checking for resolvconf...+ dpkg-query -W '-f=${Status}' resolvconf
+ printf '%b %b Checking for %s\n' '\r\033[K' '[\e[1;32m✓\e[0m]' resolvconf
[✓] Checking for resolvconf
+ for i in "$@"
[i] Checking for libcap2...+ dpkg-query -W '-f=${Status}' libcap2
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' lighttpd
[i] Checking for lighttpd...+ dpkg-query -W '-f=${Status}' lighttpd
+ echo -e '\r\033[K [i] Checking for lighttpd (will be installed)'
+ installArray+=("${i}")
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' php-common
[i] Checking for php-common...+ dpkg-query -W '-f=${Status}' php-common
+ echo -e '\r\033[K [i] Checking for php-common (will be installed)'
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' php-cgi
[i] Checking for php-cgi...+ dpkg-query -W '-f=${Status}' php-cgi
+ echo -e '\r\033[K [i] Checking for php-cgi (will be installed)'
+ for i in "$@"
+ printf ' %b Checking for %s...' '[i]' php-sqlite3
[i] Checking for php-sqlite3...+ dpkg-query -W '-f=${Status}' php-sqlite3
+ echo -e '\r\033[K [i] Checking for php-sqlite3 (will be installed)'
+ [[ 4 -gt 0 ]]
+ test_dpkg_lock
+ i=0
+ fuser /var/lib/dpkg/lock
+ return 0
+ debconf-apt-progress -- apt-get --yes --no-install-recommends install lighttpd php-common php-cgi php-sqlite3
