Hello,
I have the same problem. I can not see any white or blacklisted domains. And so it is not possible to delete old entries.
It is since I have updated to v5.
Thank you
Try clearing your browser's cache.
Hi, already done. It was not successful. I try different browser, Chrome, IE, Edge and Firefox.
Are there any errors in
sudo cat /var/log/lighttpd/error.log
Only this:
" PHP Notice: Undefined offset: 2 in /var/www/pihole-admin/scripts/pi-hole/php/update_checker.php on line 58, referer: http://192.168.0.122/pihole-admin/list.php?l=white"
This line hasn't touched in years.
Please generate a debug token with pihole -d
or via web interface and post the token here.
Token: vjkwf5zgr9
For your information. I don't use lighttpd. I use a apache2 installation for the access to the pi-hole admin page.
Thank you
Apache is an unsupported configuration. Here in the Community Help forum you will find solutions for using Apache - do a search for Apache.
with the version 4x it worked with apache for me.
But if have installed lighttpd now and everything is working correctly.
Thank you for your input.
