I run this in a trash laptop windows 10 home, i enabled wsl. Once i uninstalled and installed problem now.
_Normal run
_No IP addresses found! Please run 'pihole -r' to reconfigure when I try tp update blacklist aka gravity.
Debug Token: [✓] Your debug token is: https://tricorder.pi-hole.net/xl612as11z
Some background info :
When I update block list it shows No IP addresses found! Please run 'pihole -r' to reconfigure.
Firstly I am using windows 10 home so I installed ubuntu 16.04 LTS using WSL (yes without raspberry pi) and did something and made it work. I uninstalled and installed but now not working. and shows the above error.
From what it shows it just logs the query from ubuntu.
When i go to settings and under system it shows all unknown - https://imgur.com/a/01QiWGD
When the first time it installed it showed this:
[i] No active firewall detected.. skipping firewall configuration
[✓] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[✓] Disabling systemd-resolved DNSStubListener and restarting systemd-resolved System has not been booted with systemd as init system (PID 1). Can't operate.
only the password didn't came when but i resented using command and went well.
But in my fresh install (same ubuntu 16.04LTS) the below lines doesn't come up during installation.
(screenshot) - https://imgur.com/a/ooarj0l
with this install it doesn't show admin panel so i just run these 2 commands
sudo /etc/init.d/lighttpd restart
sudo service pihole-FTL restart
and during this install it will say no dns service running but when these 2 commands the admin panel and no dns issue disappeared
now only works on ubuntu - https://imgur.com/a/InJArFZ
From what I have seen with uninstalling and making fresh install no active firewall and man pages line were missing, if these 2 lines appears during install it work i believe.
I know you guy will ask to get a zero w pi but any answers?
what are the requirements to install pihole, i did sudo apt-get update , do i need to do upgrade?
The install stops when I do a fresh install of linux 16.04 and run this command
sudo apt install git -y
and then clone pi-hole git repository and it stops here - https://imgur.com/a/vpApYEV -RTNETLINK answers permission denied
