Whats your upstream configured DNS server(s) ? DNSSEC involved that depends on accurate date/time ?
grep 'PIHOLE_DNS\|DNSSEC' /etc/pihole/setupVars.conf
Here it is:
grep 'PIHOLE_DNS|DNSSEC' /etc/pihole/setupVars.conf
PIHOLE_DNS_3=84.200.69.80
PIHOLE_DNS_4=84.200.70.40
PIHOLE_DNS_5=9.9.9.9
PIHOLE_DNS_6=149.112.112.112
PIHOLE_DNS_7=1.1.1.1
PIHOLE_DNS_8=1.0.0.1
DNSSEC=true
PIHOLE_DNS_1=208.67.222.222
PIHOLE_DNS_2=208.67.220.220
@jfb Thanks for the tip with the debug log. I can generate a debug log via pihole -d
but I cannot upload it - no internet connection
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1
to nameserver 9.9.9.9
or your preferred third party DNS service, save and exit
Run pihole -d
and upload the debug log
Chicken egg dilemma.
Time syncing depends on DNS resolution.
And DSN resolution via DNSSEC depends on accurate date time.
Try without DNSSEC or search here on discourse for other solution's for systems that dont have a real time clock on-board like some SBC's.
Run the date
command from the Pi terminal and see if the date/time of the Pi matches your local time. If not, then reset it with the command below (you will have to substitute the correct date/time):
sudo date --set="21 December 2018 11:53:30"
Yes, the chicken egg dilemma.
I ran the date command and set date and time correct. I now have a connection to the Internet again
@jfb: The analysis of the debug file is obsolete.
Thank you guys for the help! I appreciate that very much.
