I expect internet access when rebooting router using Pi-Hole as DNS server and Pi-Hole running DNS-Over-HTTPS (Cloudflared)
When i reboot my router (Nighthawk R7000), i lose internet acces.
This only happens when i use Pi-Hole as my DNS server (changing to ISP's DNS works fine)
I can sometimes get it to work by hard rebooting my router and rebooting Pi-Hole several times and waiting 5-10 minutes, but it's not a reliable solution.
I run Cloudflared on my Pi-Hole (DNS-Over-HTTPS) using 127.0.0.1#5053 as DNS server, but recently discovered that if i change my DNS to Cloudflare (1.1.1.1 and 1.0.0.1), i get internet access immidiately.
This has worked fine for now, and i can reboot my router with no problem, but i am curious to why Cloudflared only works sometimes.
I'm having the same'ish problem. This has been happening after PG&E PSPS (power outage). My Edgerouter X is forcing all connections to the pi-hole. I can ping cloudflare but browsers give a DNS error. The way I've cleared it is to add Google DNS to the pihole and then remove it.
