root@mvps-vm1:~ # pihole version Pi-hole version is v4.0 (Latest: ERROR) AdminLTE version is v4.0 (Latest: ERROR) FTL version is v4.0 (Latest: ERROR)
root@mvps-vm1:~ # pihole updatePihole [i] Checking for updates... fatal: unable to access 'https://github.com/pi-hole/pi-hole.git/': Could not resolve host: github.com [i] Pi-hole Core: up to date fatal: unable to access 'https://github.com/pi-hole/AdminLTE.git/': Could not resolve host: github.com [i] Web Interface: up to date [i] FTL: update available [i] FTL out of date, it will be updated by the installer. [✓] Root user check .;;,. .ccccc:,. :cccclll:. ..,, :ccccclll. ;ooodc 'ccll:;ll .oooodc .;cll.;;looo:. .. ','. .',,,,,,'. .',,,,,,,,,,. .',,,,,,,,,,,,.... ....''',,,,,,,'....... ......... .... ......... .......... .......... .......... .......... ......... .... ......... ........,,,,,,,'...... ....',,,,,,,,,,,,. .',,,,,,,,,'. .',,,,,,'. ..'''. [i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u1 [i] Performing unattended setup, no whiptail dialogs will be displayed [✓] Disk space check [✓] Update local cache of available packages [✓] Checking apt-get for upgraded packages... up to date! [i] Installer Dependency checks... [✓] Checking for apt-utils [✓] Checking for dialog [✓] Checking for debconf [✓] Checking for dhcpcd5 [✓] Checking for git [✓] Checking for iproute2 [✓] Checking for whiptail [i] Performing reconfiguration, skipping download of local repos [✓] Resetting repository within /etc/.pihole... [✓] Resetting repository within /var/www/html/admin... [i] Main Dependency checks... [✓] Checking for bc [✓] Checking for cron [✓] Checking for curl [✓] Checking for dnsutils [✓] Checking for iputils-ping [✓] Checking for lsof [✓] Checking for netcat [✓] Checking for psmisc [✓] Checking for sudo [✓] Checking for unzip [✓] Checking for wget [✓] Checking for idn2 [✓] Checking for sqlite3 [✓] Checking for libcap2-bin [✓] Checking for dns-root-data [✓] Checking for resolvconf [✓] Checking for lighttpd [✓] Checking for php7.0-common [✓] Checking for php7.0-cgi [✓] Checking for php7.0-sqlite3 [✓] Enabling lighttpd service to start on reboot [✓] Installing scripts from /etc/.pihole [i] Installing configs from /etc/.pihole... [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone! [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf [i] Installing blocking page... [✓] Creating directory for blocking page, and copying files [✗] Backing up index.lighttpd.html No default index.lighttpd.html file found... not backing up [✓] Installing sudoer file [✓] Installing latest Cron script [✓] Installing latest logrotate script [i] FTL Checks... [✓] Detected x86_64 architecture [i] Checking for existing FTL binary... [✗] Downloading and Installing FTL Error: Unable to get latest release location from GitHub [✗] FTL Engine not installed [✓] man pages installed and database updated [i] Systemd-resolved is not enabled [✓] Starting lighttpd service [✓] Enabling lighttpd service to start on reboot [i] Restarting services... [✓] Starting pihole-FTL service [✓] Enabling pihole-FTL service to start on reboot [✓] Deleting existing list cache [✗] DNS resolution is currently unavailable [✗] DNS resolution is not available Unable to complete update, please contact Pi-hole Support
root@mvps-vm1:~ # cat /etc/resolv.conf # Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8) # DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN nameserver 127.0.0.1
root@mvps-vm1:~ # echo "nameserver 8.8.8.8" > /etc/resolv.conf
root@mvps-vm1:~ # cat /etc/resolv.conf nameserver 8.8.8.8
root@mvps-vm1:~ # pihole updatePihole [i] Checking for updates... [i] Pi-hole Core: update available [i] Web Interface: update available [i] FTL: update available [i] Pi-hole core files out of date, updating local repo. [✓] Check for existing repository in /etc/.pihole [✓] Update repo in /etc/.pihole [i] If you had made any changes in '/etc/.pihole/', they have been stashed using 'git stash' [i] Pi-hole Web Admin files out of date, updating local repo. [✓] Check for existing repository in /var/www/html/admin [✓] Update repo in /var/www/html/admin [i] If you had made any changes in '/var/www/html/admin/', they have been stashed using 'git stash' [i] FTL out of date, it will be updated by the installer. [✓] Root user check .;;,. .ccccc:,. :cccclll:. ..,, :ccccclll. ;ooodc 'ccll:;ll .oooodc .;cll.;;looo:. .. ','. .',,,,,,'. .',,,,,,,,,,. .',,,,,,,,,,,,.... ....''',,,,,,,'....... ......... .... ......... .......... .......... .......... .......... ......... .... ......... ........,,,,,,,'...... ....',,,,,,,,,,,,. .',,,,,,,,,'. .',,,,,,'. ..'''. [i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u1 [i] Performing unattended setup, no whiptail dialogs will be displayed [✓] Disk space check [✓] Update local cache of available packages [✓] Checking apt-get for upgraded packages... up to date! [i] Installer Dependency checks... [✓] Checking for apt-utils [✓] Checking for dialog [✓] Checking for debconf [✓] Checking for dhcpcd5 [✓] Checking for git [✓] Checking for iproute2 [✓] Checking for whiptail [i] Performing reconfiguration, skipping download of local repos [✓] Resetting repository within /etc/.pihole... [✓] Resetting repository within /var/www/html/admin... [i] Main Dependency checks... [✓] Checking for bc [✓] Checking for cron [✓] Checking for curl [✓] Checking for dnsutils [✓] Checking for iputils-ping [✓] Checking for lsof [✓] Checking for netcat [✓] Checking for psmisc [✓] Checking for sudo [✓] Checking for unzip [✓] Checking for wget [✓] Checking for idn2 [✓] Checking for sqlite3 [✓] Checking for libcap2-bin [✓] Checking for dns-root-data [✓] Checking for resolvconf [✓] Checking for lighttpd [✓] Checking for php7.0-common [✓] Checking for php7.0-cgi [✓] Checking for php7.0-sqlite3 [✓] Enabling lighttpd service to start on reboot... [✓] Checking for user 'pihole' [✓] Installing scripts from /etc/.pihole [i] Installing configs from /etc/.pihole... [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone! [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf [i] Installing blocking page... [✓] Creating directory for blocking page, and copying files [✗] Backing up index.lighttpd.html No default index.lighttpd.html file found... not backing up [✓] Installing sudoer file [✓] Installing latest Cron script [✓] Installing latest logrotate script [i] FTL Checks... [✓] Detected x86_64 architecture [i] Checking for existing FTL binary... [✓] Downloading and Installing FTL [i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old [✓] man pages installed and database updated [i] Testing if systemd-resolved is enabled [i] Systemd-resolved is not enabled [✓] Starting lighttpd service... [✓] Enabling lighttpd service to start on reboot... [i] Restarting services... [✓] Enabling pihole-FTL service to start on reboot... [✓] Starting pihole-FTL service... [✓] Deleting existing list cache [i] Pi-hole blocking is enabled [✗] DNS resolution is currently unavailable [✓] DNS resolution is now available [i] Neutrino emissions detected... [✓] Pulling blocklist source list into range [i] Target: raw.githubusercontent.com (hosts) [✓] Status: Retrieval successful [i] Target: mirror1.malwaredomains.com (justdomains) [✓] Status: Retrieval successful [i] Target: sysctl.org (hosts) [✓] Status: Retrieval successful [i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist) [✓] Status: Retrieval successful [i] Target: s3.amazonaws.com (simple_tracking.txt) [✓] Status: Retrieval successful [i] Target: s3.amazonaws.com (simple_ad.txt) [✓] Status: Retrieval successful [i] Target: hosts-file.net (ad_servers.txt) [✓] Status: Retrieval successful [i] Target: github.com (spy.txt) [✓] Status: Retrieval successful [i] Target: localhost (adblock.hosts) [✓] Status: Retrieval successful [i] Received empty file: using previously cached list [i] Target: raw.githubusercontent.com (anti-adblock-killer-filters.txt) [✓] Status: Retrieval successful [i] Format: Adblockcomm: file 1 is not in sorted order [✓] Format: Adblock [i] Target: raw.githubusercontent.com (trackers.txt) [✓] Status: Retrieval successful [✓] Consolidating blocklists [✓] Extracting domains from blocklists [i] Number of domains being pulled in by gravity: 174623 [✓] Removing duplicate domains [i] Number of unique domains trapped in the Event Horizon: 150533 [i] Number of whitelisted domains: 10 [i] Number of blacklisted domains: 4 [i] Number of regex filters: 1 [✓] Parsing domains into hosts format [✓] Cleaning up stray matter [✓] Force-reloading DNS service [✗] DNS service is NOT running [i] The install log is located at: /etc/pihole/install.log Update Complete! Current Pi-hole version is v4.1 Current AdminLTE version is v4.1 Current FTL version is v4.1
root@mvps-vm1:~ # pihole updateGravity [i] Pi-hole blocking is enabled [i] Neutrino emissions detected... [✓] Pulling blocklist source list into range [i] Target: raw.githubusercontent.com (hosts) [✓] Status: Retrieval successful [i] Target: mirror1.malwaredomains.com (justdomains) [✓] Status: No changes detected [i] Target: sysctl.org (hosts) [✓] Status: No changes detected [i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist) [✓] Status: No changes detected [i] Target: s3.amazonaws.com (simple_tracking.txt) [✓] Status: No changes detected [i] Target: s3.amazonaws.com (simple_ad.txt) [✓] Status: No changes detected [i] Target: hosts-file.net (ad_servers.txt) [✓] Status: No changes detected [i] Target: github.com (spy.txt) [✓] Status: Retrieval successful [i] Target: localhost (adblock.hosts) [✓] Status: Retrieval successful [i] Received empty file: using previously cached list [i] Target: raw.githubusercontent.com (anti-adblock-killer-filters.txt) [✓] Status: Retrieval successful [i] Format: Adblockcomm: file 1 is not in sorted order [✓] Format: Adblock [i] Target: raw.githubusercontent.com (trackers.txt) [✓] Status: Retrieval successful [✓] Consolidating blocklists [✓] Extracting domains from blocklists [i] Number of domains being pulled in by gravity: 174623 [✓] Removing duplicate domains [i] Number of unique domains trapped in the Event Horizon: 150533 [i] Number of whitelisted domains: 10 [i] Number of blacklisted domains: 4 [i] Number of regex filters: 1 [✓] Parsing domains into hosts format [✓] Cleaning up stray matter [✓] Force-reloading DNS service [✗] DNS service is NOT running
root@mvps-vm1:~ # pihole restartdns [✓] Restarting DNS service
root@mvps-vm1:~ # pihole debug# [...] [?] Would you like to upload the log? [y/N] y * Using openssl for transmission. [✗] There was an error uploading your debug log. * Please try again or contact the Pi-hole team for assistance. * A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
i change the resolv and do a new debug.
root@mvps-vm1:~ # pihole debug This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net. The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development. NOTE: All log files auto-delete after 48 hours and ONLY the Pi-hole developers can access your data via the given token. We have taken these extra steps to secure your data and will work to further reduce any personal information gathered. *** [ INITIALIZING ] [i] 2018-12-12:20:56:30 debug log has been initialized. *** [ INITIALIZING ] Sourcing setup variables [i] Sourcing /etc/pihole/setupVars.conf... *** [ DIAGNOSING ]: Core version [i] Core: v4.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249) [i] Branch: master [i] Commit: v4.1-0-gf65f793 *** [ DIAGNOSING ]: Web version [i] Web: v4.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249) [i] Branch: master [i] Commit: v4.1-0-g5ec769d9 *** [ DIAGNOSING ]: FTL version [✓] FTL: v4.1 *** [ DIAGNOSING ]: lighttpd version [i] 1.4.45 *** [ DIAGNOSING ]: php version [i] 7.0.33 *** [ DIAGNOSING ]: Operating system [✓] Debian GNU/Linux 9 (stretch) *** [ DIAGNOSING ]: SELinux [i] SELinux not detected *** [ DIAGNOSING ]: Processor [i] x86_64 *** [ DIAGNOSING ]: Networking [✓] IPv4 address(es) bound to the eth0 interface: 194.99.21.232/24 matches the IP found in /etc/pihole/setupVars.conf [✓] IPv6 address(es) bound to the eth0 interface: fe80::9b6b:fc24:fb80:73a4 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127) ^ Please note that you may have more than one IP address listed. As long as one of them is green, and it matches what is in /etc/pihole/setupVars.conf, there is no need for concern. The link to the FAQ is for an issue that sometimes occurs when the IPv6 address changes, which is why we check for it. [i] Default IPv4 gateway: 194.99.21.1 * Pinging 194.99.21.1... [✓] Gateway responded. *** [ DIAGNOSING ]: Ports in use *:111 rpcbind (IPv4) *:111 rpcbind (IPv6) *:22 sshd (IPv4) *:22 sshd (IPv6) *:4200 shellinabo (IPv4) [*:80] is in use by lighttpd [*:80] is in use by lighttpd [*:53] is in use by pihole-FTL [*:53] is in use by pihole-FTL [127.0.0.1:4711] is in use by pihole-FTL [[::1]:4711] is in use by pihole-FTL 194.99.21.232:5666 nrpe (IPv4) *** [ DIAGNOSING ]: Name resolution (IPv4) using a random blocked domain and a known ad-serving domain [✗] Failed to resolve px-conf.perimeterx.net via localhost (127.0.0.1) [✗] Failed to resolve px-conf.perimeterx.net via Pi-hole (194.99.21.232) [✓] doubleclick.com is 64.233.177.138 via a remote, public DNS server (8.8.8.8) *** [ DIAGNOSING ]: Pi-hole processes [✓] lighttpd daemon is active [✓] pihole-FTL daemon is active *** [ DIAGNOSING ]: Setup variables PIHOLE_INTERFACE=eth0 IPV4_ADDRESS=194.99.21.232/24 IPV6_ADDRESS= PIHOLE_DNS_1=8.8.8.8 PIHOLE_DNS_2=8.8.4.4 QUERY_LOGGING=true INSTALL_WEB_SERVER=true INSTALL_WEB_INTERFACE=true LIGHTTPD_ENABLED=true *** [ DIAGNOSING ]: Dashboard and block page [✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements. [✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working! *** [ DIAGNOSING ]: Gravity list -rw-r--r-- 1 root root 3403135 Dez 12 20:24 /etc/pihole/gravity.list -----head of gravity.list------ !rdio.com -x3.vindicosuite.com 0-hjsochvj-ios-1-2-3.mobile-sdk-api.intercom.io 0-jovd32f9-ios-7-0-1.mobile-sdk-api.intercom.io -----tail of gravity.list------ zzz.clickbank.net zzzezeroe.fr zzzpooeaz-france.com zzzrtrcm2.com *** [ DIAGNOSING ]: contents of /etc/pihole -rw-r--r-- 1 root root 658 Nov 27 03:10 /etc/pihole/adlists.list https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts https://mirror1.malwaredomains.com/files/justdomains http://sysctl.org/cameleon/hosts https://zeustracker.abuse.ch/blocklist.php?download=domainblocklist https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt https://hosts-file.net/ad_servers.txt https://github.com/crazy-max/WindowsSpyBlocker/blob/master/data/hosts/spy.txt http://localhost/adblock.hosts https://raw.githubusercontent.com/reek/anti-adblock-killer/master/anti-adblock-killer-filters.txt https://raw.githubusercontent.com/quidsup/notrack/master/trackers.txt -rw-r--r-- 1 root root 62 Nov 27 02:37 /etc/pihole/blacklist.txt www.coin-hive.com coin-hive.com www.coinhive.com coinhive.com -rw-r--r-- 1 root root 45 Dez 12 20:24 /etc/pihole/local.list 194.99.21.232 mvps-vm1 194.99.21.232 pi.hole -rw-r--r-- 1 root root 234 Dez 12 20:17 /etc/pihole/logrotate /var/log/pihole.log { su root root daily copytruncate rotate 5 compress delaycompress notifempty nomail } /var/log/pihole-FTL.log { su root root weekly copytruncate rotate 3 compress delaycompress notifempty nomail } -rw-r--r-- 1 root root 165 Nov 27 02:37 /etc/pihole/whitelist.txt raw.githubusercontent.com mirror1.malwaredomains.com sysctl.org zeustracker.abuse.ch s3.amazonaws.com hosts-file.net localhost outlook.live.com sharewareonsale.com *** [ DIAGNOSING ]: contents of /etc/dnsmasq.d -rw-r--r-- 1 root root 1413 Dez 12 20:17 /etc/dnsmasq.d/01-pihole.conf addn-hosts=/etc/pihole/gravity.list addn-hosts=/etc/pihole/black.list addn-hosts=/etc/pihole/local.list user=pihole group=pihole localise-queries no-resolv cache-size=10000 log-queries log-facility=/var/log/pihole.log local-ttl=2 log-async server=8.8.8.8 server=8.8.4.4 interface=eth0 *** [ DIAGNOSING ]: contents of /etc/lighttpd -rw-r--r-- 1 root root 3102 Dez 12 20:17 /etc/lighttpd/lighttpd.conf server.modules = ( "mod_access", "mod_accesslog", "mod_auth", "mod_expire", "mod_compress", "mod_redirect", "mod_setenv", "mod_rewrite" ) server.document-root = "/var/www/html" server.error-handler-404 = "pihole/index.php" server.upload-dirs = ( "/var/cache/lighttpd/uploads" ) server.errorlog = "/var/log/lighttpd/error.log" server.pid-file = "/var/run/lighttpd.pid" server.username = "www-data" server.groupname = "www-data" server.port = 80 accesslog.filename = "/var/log/lighttpd/access.log" accesslog.format = "%{%s}t|%V|%r|%s|%b" index-file.names = ( "index.php", "index.html", "index.lighttpd.html" ) url.access-deny = ( "~", ".inc", ".md", ".yml", ".ini" ) static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" ) compress.cache-dir = "/var/cache/lighttpd/compress/" compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" ) include_shell "/usr/share/lighttpd/use-ipv6.pl " + server.port include_shell "/usr/share/lighttpd/create-mime.assign.pl" include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include \"%p\" ' 2>/dev/null" $HTTP["url"] =~ "^/admin/" { setenv.add-response-header = ( "X-Pi-hole" => "The Pi-hole Web interface is working!", "X-Frame-Options" => "DENY" ) $HTTP["url"] =~ ".ttf$" { setenv.add-response-header = ( "Access-Control-Allow-Origin" => "*" ) } } $HTTP["url"] =~ "^/admin/\.(.*)" { url.access-deny = ("") } include_shell "cat external.conf 2>/dev/null" *** [ DIAGNOSING ]: contents of /etc/cron.d -rw-r--r-- 1 root root 1703 Dez 12 20:17 /etc/cron.d/pihole 8 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log 00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet @reboot root /usr/sbin/logrotate /etc/pihole/logrotate */10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local 18 15 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote @reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot *** [ DIAGNOSING ]: contents of /var/log/lighttpd -rw-r--r-- 1 www-data www-data 17585 Dez 12 20:55 /var/log/lighttpd/error.log 2018-12-10 06:25:03: (server.c.1534) logfiles cycled UID = 0 PID = 20604 2018-12-10 07:12:01: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 07:12:03: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 09:12:57: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 09:47:39: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 11:23:17: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 11:28:11: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 13:02:04: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 20:44:31: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 21:32:24: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-10 21:32:25: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 03:54:59: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 03:56:58: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 05:20:25: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 06:25:40: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 11:18:46: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 11:25:29: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 12:01:25: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 12:02:36: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 12:03:49: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 12:09:53: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 12:27:54: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 12:42:39: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 12:50:34: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 2018-12-11 13:16:43: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10 *** [ DIAGNOSING ]: contents of /var/log -rw-r--r-- 1 pihole pihole 10562 Dez 12 20:27 /var/log/pihole-FTL.log -----head of pihole-FTL.log------ [2018-12-12 19:37:45.196] ########## FTL started! ########## [2018-12-12 19:37:45.196] FTL branch: [2018-12-12 19:37:45.196] FTL version: v4.0 [2018-12-12 19:37:45.200] FTL commit: 8493df4 [2018-12-12 19:37:45.200] FTL date: 2018-08-05 13:40:30 -0700 [2018-12-12 19:37:45.200] FTL user: pihole [2018-12-12 19:37:45.200] Starting config file parsing (/etc/pihole/pihole-FTL.conf) [2018-12-12 19:37:45.200] SOCKET_LISTENING: only local [2018-12-12 19:37:45.200] AAAA_QUERY_ANALYSIS: Show AAAA queries [2018-12-12 19:37:45.200] MAXDBDAYS: max age for stored queries is 365 days [2018-12-12 19:37:45.200] RESOLVE_IPV6: Resolve IPv6 addresses [2018-12-12 19:37:45.200] RESOLVE_IPV4: Resolve IPv4 addresses [2018-12-12 19:37:45.200] DBINTERVAL: saving to DB file every minute [2018-12-12 19:37:45.200] DBFILE: Using /etc/pihole/pihole-FTL.db [2018-12-12 19:37:45.200] MAXLOGAGE: Importing up to 24.0 hours of log data [2018-12-12 19:37:45.200] PRIVACYLEVEL: Set to 0 [2018-12-12 19:37:45.200] IGNORE_LOCALHOST: Show queries from localhost [2018-12-12 19:37:45.201] BLOCKINGMODE: Null IPs for blocked domains [2018-12-12 19:37:45.201] REGEX_DEBUGMODE: Inactive [2018-12-12 19:37:45.201] Finished config file parsing [2018-12-12 19:37:45.201] Skipping empty regex filter on line 1 [2018-12-12 19:37:45.201] Compiled 0 Regex filters and 10 whitelisted domains in 0.1 msec (0 errors) [2018-12-12 19:37:45.202] Database successfully initialized [2018-12-12 19:37:45.202] Imported 0 queries from the long-term database [2018-12-12 19:37:45.203] -> Total DNS queries: 0 [2018-12-12 19:37:45.203] -> Cached DNS queries: 0 [2018-12-12 19:37:45.203] -> Forwarded DNS queries: 0 [2018-12-12 19:37:45.203] -> Exactly blocked DNS queries: 0 [2018-12-12 19:37:45.203] -> Unknown DNS queries: 0 [2018-12-12 19:37:45.203] -> Unique domains: 0 [2018-12-12 19:37:45.203] -> Unique clients: 0 [2018-12-12 19:37:45.203] -> Known forward destinations: 0 [2018-12-12 19:37:45.203] Successfully accessed setupVars.conf [2018-12-12 19:37:45.215] PID of FTL process: 3256 [2018-12-12 19:37:45.215] Listening on port 4711 for incoming IPv4 telnet connections -----tail of pihole-FTL.log------ [2018-12-12 20:27:16.423] BLOCKINGMODE: Null IPs for blocked domains [2018-12-12 20:27:16.423] REGEX_DEBUGMODE: Inactive [2018-12-12 20:27:16.423] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries [2018-12-12 20:27:16.423] DBIMPORT: Importing history from database [2018-12-12 20:27:16.423] PIDFILE: Using /var/run/pihole-FTL.pid [2018-12-12 20:27:16.423] PORTFILE: Using /var/run/pihole-FTL.port [2018-12-12 20:27:16.423] SOCKETFILE: Using /var/run/pihole/FTL.sock [2018-12-12 20:27:16.423] WHITELISTFILE: Using /etc/pihole/whitelist.txt [2018-12-12 20:27:16.423] BLACKLISTFILE: Using /etc/pihole/black.list [2018-12-12 20:27:16.423] GRAVITYFILE: Using /etc/pihole/gravity.list [2018-12-12 20:27:16.423] REGEXLISTFILE: Using /etc/pihole/regex.list [2018-12-12 20:27:16.423] SETUPVARSFILE: Using /etc/pihole/setupVars.conf [2018-12-12 20:27:16.423] AUDITLISTFILE: Using /etc/pihole/auditlog.list [2018-12-12 20:27:16.423] Finished config file parsing [2018-12-12 20:27:16.423] Skipping empty regex filter on line 1 [2018-12-12 20:27:16.424] Compiled 0 Regex filters and 10 whitelisted domains in 0.1 msec (0 errors) [2018-12-12 20:27:16.428] Database successfully initialized [2018-12-12 20:27:16.428] Imported 0 queries from the long-term database [2018-12-12 20:27:16.428] -> Total DNS queries: 0 [2018-12-12 20:27:16.428] -> Cached DNS queries: 0 [2018-12-12 20:27:16.428] -> Forwarded DNS queries: 0 [2018-12-12 20:27:16.428] -> Exactly blocked DNS queries: 0 [2018-12-12 20:27:16.428] -> Unknown DNS queries: 0 [2018-12-12 20:27:16.429] -> Unique domains: 0 [2018-12-12 20:27:16.429] -> Unique clients: 0 [2018-12-12 20:27:16.429] -> Known forward destinations: 0 [2018-12-12 20:27:16.429] Successfully accessed setupVars.conf [2018-12-12 20:27:16.439] PID of FTL process: 8559 [2018-12-12 20:27:16.440] Listening on port 4711 for incoming IPv4 telnet connections [2018-12-12 20:27:16.440] Listening on port 4711 for incoming IPv6 telnet connections [2018-12-12 20:27:16.440] Listening on Unix socket [2018-12-12 20:27:16.440] Skipping empty regex filter on line 1 [2018-12-12 20:27:16.440] Compiled 0 Regex filters and 10 whitelisted domains in 0.1 msec (0 errors) [2018-12-12 20:27:16.450] /etc/pihole/black.list: parsed 4 domains (took 0.0 ms) [2018-12-12 20:27:16.826] /etc/pihole/gravity.list: parsed 150531 domains (took 375.3 ms) *** [ DIAGNOSING ]: Locale LANG=de_DE.UTF-8 *** [ DIAGNOSING ]: Pi-hole log -rw-r--r-- 1 pihole pihole 2816 Dez 12 20:27 /var/log/pihole.log -----head of pihole.log------ Dec 12 19:37:43 dnsmasq[10010]: exiting on receipt of SIGTERM Dec 12 19:37:45 dnsmasq[3256]: started, version pi-hole-2.79 cachesize 10000 Dec 12 19:37:45 dnsmasq[3256]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify Dec 12 19:37:45 dnsmasq[3256]: warning: failed to change owner of /var/log/pihole.log: Operation not permitted Dec 12 19:37:45 dnsmasq[3256]: using nameserver 8.8.4.4#53 Dec 12 19:37:45 dnsmasq[3256]: using nameserver 8.8.8.8#53 Dec 12 19:37:45 dnsmasq[3256]: read /etc/hosts - 3 addresses Dec 12 19:37:45 dnsmasq[3256]: read /etc/pihole/local.list - 2 addresses Dec 12 19:37:45 dnsmasq[3256]: read /etc/pihole/black.list - 8 addresses Dec 12 19:37:46 dnsmasq[3256]: read /etc/pihole/gravity.list - 307262 addresses Dec 12 20:17:17 dnsmasq[3256]: exiting on receipt of SIGTERM Dec 12 20:17:19 dnsmasq[7033]: started, version pi-hole-2.79 cachesize 10000 Dec 12 20:17:19 dnsmasq[7033]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify Dec 12 20:17:19 dnsmasq[7033]: using nameserver 8.8.4.4#53 Dec 12 20:17:19 dnsmasq[7033]: using nameserver 8.8.8.8#53 Dec 12 20:17:19 dnsmasq[7033]: read /etc/hosts - 3 addresses Dec 12 20:17:19 dnsmasq[7033]: read /etc/pihole/local.list - 2 addresses Dec 12 20:17:19 dnsmasq[7033]: read /etc/pihole/black.list - 8 addresses Dec 12 20:17:20 dnsmasq[7033]: read /etc/pihole/gravity.list - 307262 addresses Dec 12 20:18:16 dnsmasq[7033]: read /etc/hosts - 3 addresses ******************************************** ******************************************** [✓] ** FINISHED DEBUGGING! ** * The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only. * For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/ * If available, we'll use openssl to upload the log, otherwise it will fall back to netcat. [?] Would you like to upload the log? [y/N] y * Using openssl for transmission. *********************************** *********************************** [✓] Your debug token is: 8nxbinyms3 *********************************** *********************************** * Provide the token above to the Pi-hole team for assistance at * https://discourse.pi-hole.net * Your log will self-destruct on our server after 48 hours. * A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
am I doing something wrong?
