I can not access the admin page at all. I have followed many of these reports but nothing has worked
Admin page should load
404 error or server not found
What is the exact URL you are typing into the browser window?
Can you provide a screen snap of the resulting message? You can paste a snap directly into your reply.
Are you putting http:// before the address?
Yes
and then it switches to only the address
I just used another SD card and I finally can gain access. The other 2 I used are the same new ones So i can only assume that it is a fluke. Thank you for helping and for anyone reading this with the same problem try a few SD cards
