instead of lighttpd
_[ I expect that when blocks occur that activity would be logged and thus visible in the query log or dashboard on the admin web page.
Pi-hole version is V5.2.4
AdminLTE version is V5.4
FTL version is V5.7
SQLite version is 3.27.2
Pi-hole Host
Hardware = Raspberry Pi Zero WH
OS= Name="Raspbian GNU/Linux", Version_ID="10",VERSION_CODENAME=buster
Networking is Wifi using DHCP from an AT&T modem/router which has the Pi-hole host IP address "Allocated"/ Reserved.
OS is up to date as of 2/20/21
Client used for testing:
Hardware = Raspberry Pi 4
OS = Name "Raspbian GNU/Linux 10 (buster), Version_ID=10,
Networking is wired ethernet and DHPC where the DNS to be used from the DHCP query is over ridden from the following entry into /etc/dhcp/dhclient.conf "supersede domain-name-servers 192.168.1.184;" where the local .184 address is that of the Pi-hole server.
Actions thus far beyond updating everything:
1) Noted /etc/pihole/setupVars.conf shows QUERY_LOGGING=true
2) Used web admin interface to disable/enable query logging
3) Used web admin interface to flush logs
4) Re-created FTL database vi:
a) service pihole-FTL stop
b) mv pihole-FTL.db pihole-FTL.db.old
c) service pihole-FTL start
5) issued and completed "pihole -r" command
6) Confirmed both Pihole server and Pihole client obtained the same results from "nslookup flurry.com"
7-9) A lot of praying, cussing, chanting...... the usual stuff when faced with my many limitations :-)
_[
The client used for testing seems to have ads blocked but no entries show up in the web interface other than what appear to be unrelated entries from "localhost". There are no entries other than those from localhost.
It may or may not be worth noting, because I am definitely not a database guy...... But curiosity got the better of me so I went into the sqlite3 database, opened the pihole-FTL.db database, and listed, to the screen, the contents of "name" in the "network_addresses" table and while the list was as long as the output I recieved from "ip" in the same table, BUT all the lines in the output were blank except for one which had the value of "localhost".
Hopefully I have given you enough information to be able to let me know what in the world I've done wrong or missed. I would definitely be grateful for any assistance, because Pi-Hole looks extremely COOL.....
Last Note, Wow didn't expect getting the token would do all that. I thought it would simply give me some number or such.... Man you guys have really got your stuff together....
Thank You
Dee
]_
