Thank you @PA3DSS. I was more interested in if its a list that is maintained, as the filesize does not particulally bother me. If it is not continuously being maintained I dont see much use for it in my use case.
Even without a header does not mean it is not good to use. If you can access the link, then the list at least can be added to your pi-hole. You just don't know how often they update it to remove false positives.
No longer maintained and dubious as to quantity/quality. Closing this thread.
