same answer as the above -- server: unknown
Same address? Copy over the exact output from ipconfig /all
please.
Do you know why that client would be using an IPv6 address from Vultr?
This is from my laptop currently with you on the forum - no problem with. Only on the student's laptop with that IPv6
C:\>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Rdell
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 1:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 5E-EA-1D-2D-13-8B
Wireless LAN adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 6E-EA-1D-2D-13-8B
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Qualcomm QCA61x4A 802.11ac Wireless Adapter
Physical Address. . . . . . . . . : 5C-EA-1D-2D-13-8B
Link-local IPv6 Address . . . . . : fe80::481b:8aec:1ea8:c7c9%18(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.85(Preferred)
Lease Obtained. . . . . . . . . . : Monday, December 2, 2019 3:24:06 PM
Lease Expires . . . . . . . . . . : Monday, December 2, 2019 11:42:37 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 39643677
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-19-9F-63-5C-EA-1D-2D-13-8B
DNS Servers . . . . . . . . . . . : 192.168.1.57
Ethernet adapter Bluetooth Network Connection 4:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #4
Physical Address. . . . . . . . . : 5C-EA-1D-2D-13-8C
So, to clarify, that output is from a working configuration?
yes the above is from my laptop. Working. I will copy and paste from my student's laptop
This is from the student's laptop.
C:\Users\mawar>ipconfig /all
Host Name . . . . . . . . . . . . : LAPTOP-K63OIKAC
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 9C-7B-EF-6B-74-CD
Physical Address. . . . . . . . . : DE-F5-05-7E-A2-DD
Description . . . . . . . . . . . : Realtek RTL8723DE 802.11b/g/n PCIe Adapter
Physical Address. . . . . . . . . : DC-F5-05-7E-A2-DD
Link-local IPv6 Address . . . . . : fe80::f815:a21:c82b:e218%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.172(Preferred)
Lease Obtained. . . . . . . . . . : 02 December 2019 16:01:15
Lease Expires . . . . . . . . . . : 03 December 2019 00:01:15
DHCPv6 IAID . . . . . . . . . . . : 115143941
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-46-69-44-9C-7B-EF-6B-74-CD
DNS Servers . . . . . . . . . . . : 2001:19f0:5001:3588:5400:2ff:fe12:79d7
2001:41d0:302:2200::1067
192.168.1.57
Ethernet adapter Bluetooth Network Connection:
Physical Address. . . . . . . . . : DC-F5-05-7E-A2-DC
Fix that and it will work.
I found it. Student's IPv6 is set manually with the numbers.
Wireless LAN adapter Local Area Connection* 2:
Lease Obtained. . . . . . . . . . : 02 December 2019 16:09:27
Lease Expires . . . . . . . . . . : 03 December 2019 00:09:27
C:\windows\system32>nslookup pi.hole
Server: eduseeds
Address: 192.168.1.57
Pi hole is working on the student's laptop. But as I can see from the Pi-hole dashboard, I still could not see 192.168.1.172 activated. It is still in pink for this ip address.
On the Query Log tab, 192.168.1.83 picked up the domain youtube.com from this laptop.
Where does this 192.168.1.83 come from?
You'll have to check your network to find out. And the client page will update in a short period of time to reflect the clients using Pi-hole, it's not an instant change.
when I ping 192.168.1.83 it is unreachable
